![]() | Home > Maintenance & Mods (L322) > Torque Converter gone...? |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
And a firm in Harlow that will road test it and plug it in to see what fault codes are reported..
Update - Took it to an auto specialist over near Harlow and he couldn't really feel much by way of vibration.... So for now he said it's worth adding a tube of "Shuddderfix" and see how it goes.
Rich_Allen Member Since: 05 Jan 2015 Location: Rutland Posts: 79 ![]() ![]() ![]() |
I have used 'Dr Tranny Shudder Fix' in several sports and discos in the past and its amazing stuff... Normally get another 20k out of the torque convertor before needing to replace |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
Ash I'm pretty sure the IID Tool will capture the data you need.
Sorry to pull up and old thread..... But I Have my shudder back again - 3 years down the line and 30k miles more on the clock.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
chuck some more shudder |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 113 ![]() ![]() ![]() |
Hi,
So I plugged IID in this evening to pull some values
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Give Martin Hind at Dartford Transmissions and Autocare a call |
Sorry chaps
Kevio Member Since: 18 Feb 2020 Location: Wiltshire Posts: 10 ![]() ![]() ![]() |
I had an oil and filter(sump) change less than 100 miles ago and had a loss of power and high revs going round a roundabout then was coming home from collecting the kids and got the judder until i eased off the power. Will ring the garage that did the job in the morning. Have they f@@ked my gearbox. Its a 8hp70 on a 4.4 tdv8. |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
My sticking caliper was noticeable more at 50-70 and the heat generated was obvious in the alloy wheel. I could feel the heat on my hand without touching it. 2011 4.4tdv8 Vogue Baltic Blue |
