Home > Maintenance & Mods (L322) > Torque Converter gone...? |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
And a firm in Harlow that will road test it and plug it in to see what fault codes are reported..
13th Jul 2017 8:10am |
Update - Took it to an auto specialist over near Harlow and he couldn't really feel much by way of vibration.... So for now he said it's worth adding a tube of "Shuddderfix" and see how it goes.
24th Jul 2017 7:15pm |
Rich_Allen Member Since: 05 Jan 2015 Location: Rutland Posts: 76 |
I have used 'Dr Tranny Shudder Fix' in several sports and discos in the past and its amazing stuff... Normally get another 20k out of the torque convertor before needing to replace |
3rd Aug 2017 11:40am |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 608 |
Ash I'm pretty sure the IID Tool will capture the data you need.
4th Aug 2017 9:52pm |
Sorry to pull up and old thread..... But I Have my shudder back again - 3 years down the line and 30k miles more on the clock.
2nd Feb 2020 7:16pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
chuck some more shudder fix in |
2nd Feb 2020 9:13pm |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 113 |
Hi,
2nd Feb 2020 9:49pm |
So I plugged IID in this evening to pull some values
3rd Feb 2020 8:58pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
Give Martin Hind at Dartford Transmissions and Autocare a call
3rd Feb 2020 9:10pm |
Sorry chaps
18th Feb 2020 12:59pm |
Kevio Member Since: 18 Feb 2020 Location: Wiltshire Posts: 10 |
I had an oil and filter(sump) change less than 100 miles ago and had a loss of power and high revs going round a roundabout then was coming home from collecting the kids and got the judder until i eased off the power. Will ring the garage that did the job in the morning. Have they f@@ked my gearbox. Its a 8hp70 on a 4.4 tdv8. |
25th Feb 2020 6:47pm |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 |
My sticking caliper was noticeable more at 50-70 and the heat generated was obvious in the alloy wheel. I could feel the heat on my hand without touching it. 2011 4.4tdv8 Vogue Baltic Blue |
25th Feb 2020 9:07pm |
