Home > In Car Electronics (L322) > Venture Cam Repair.
Page 4 of 4 <1234
CEEGEE
dolph34 wrote:
Cam repaired. Thank you. Showed kids , played with it for about 10 mins and that's Proberbly the last time it will be used Very Happy
Sounds about right - it was 'a gimmick too far' in my view Whistle
Post #383604 24th Apr 2016 11:14pm
e600
United Kingdom 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi all
Excellent posts re fixing the unit many thanks. I opened mine without breaking the tang off the case, taking advice from the thread but noted that the small plastic clips securing wires had disintegrated and the battery pack has slightly discharged green gunge! also the 2 black wires from the battery pack were free floating in the case.
This soldering work is beyond my limited skills so is anyone taking these on a a paying repair job/hobby?
If so could you please let me know as I would like to get this fixed
TIA
Post #384314 28th Apr 2016 5:34pm
Dieterf
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Grrrrr, annoyed
Took the battery pack to a local "repacker", who promptly made another.
Plugged the new pack into the card and torch worked, could also cycle thru the modes.
Came home to assemble properly with sealant etc and now wont work!
Have output voltage 8.1 V, as batteries are fully charged.
Wires on plug well connected, no obvious handling damage.
cant figure out whats gone wrong from collection to now Big Cry
Post #384460 29th Apr 2016 3:23pm
e600
Bought a camera and docking station from E Bay, once charged all is fine, had a play and put it away, probably not to be used again, but at least I know it works.
Post #385577 6th May 2016 5:00pm
ConB
Hi guys,
Started this repair yesterday on my own venture cam only to find that the thermistor had completly disintegrated.
Anyone know the correct type and value or have a sharp enough photo to identify it.
Thanks to anyone that can help.
Post #413188 12th Nov 2016 12:15pm
CharlieBaja
United Kingdom 2007 Range Rover Autobiography TDV8 Buckingham Blue
Thank you Dave for these detailed instructions on how to take apart the camera and reset the new batteries. Camera is back up and running and charging well.
Post #413848 15th Nov 2016 11:21pm
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
My Venturecam was dead so made up a new battery pack with cells got off ebay, thanks to the info got from here. All now working. Hopefully will now also stop getting random "venture cam window" appearing on screen. Would be interested what anyone has actually used their Venturecam for, e.g. off-roading, or hitching a trailer?
Post #446559 3rd Aug 2017 6:41pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I use mine to show people I've got a venture cam !!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #446582 3rd Aug 2017 10:34pm
Alfasprint88
New Zealand 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I once used mine to help reverse my trailer in to a tight space. I found that the factory fitted mirrors worked better.
Post #446667 4th Aug 2017 9:33pm
mistleymike
ConB wrote:
Hi guys,
I have the same problem - repeating the same question - type and value of thermistor? Anyone?
Post #494775 6th Nov 2018 11:31am
Page 4 of 4 <1234
