Home > In Car Electronics (L322) > Venture Cam Repair.
Page 2 of 4 <1234>
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
I ve done the repair, and i have no problem with the pairing of the camera, but my camera doensnt charge.
It indicates that it is in the cradle, it indicates that the battery is charging, but when I power it, it just dies.
Help!
Post #232915 5th Jan 2014 12:38am
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
VMPP, have you left it charging for long enough? You may need to keep it in the charger during a long journey.
Also did you use higher capacity batteries, original items are approximately 700mah, I replaced mine with 850mah good quality batteries. Very Happy
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #233124 5th Jan 2014 10:21pm
VMPP
Yes, it has now been on the car for some time.
They worked pretty well as they were precharged by me.
But in the car, the indicator climbs, but the cam, as soon as it powers, dies down immediately.
I bought some of these:
http://www.gpbatteries.com/INT/index.php
Post #233453 7th Jan 2014 6:19pm
^ I would open it up again and double check the wiring... Just in case.. Previously..
Post #233457 7th Jan 2014 6:36pm
supershuttle
Just done this camera now works Thumbs Up
Only one word of caution, the two halves are held together by three plastic clips and the black sealant, one of the clips is in the centre at the bottom (opposite the lens) if you're too enthusiastic you'll damage or even break it. It is as the OP states the place to start prising apart but just avoid the centre and you won't break anything.
HTH Geoff
Post #246594 6th Mar 2014 9:05am
TerryT-J
Wales 2005 Range Rover Vogue Td6 Java Black
Iv'e just done this as well but as others say watch out for that single clip. I split mine but managed to weld it back together with the soldering iron. I got my rechargable batteries from Maplins. Their own brand, 1000mah and 12.99 for a pack of 12 so you can make up a second pack ready for when your first one fails!!!! Thumbs Up
Post #246664 6th Mar 2014 4:14pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
My camera shuts down just after a second or two of image and then I only get static on the screen; however the orange leds stay on forever (well, for a very long time anyway, I left it on for at least an hour)… Does this still mean the batteries are the problem? Or should the leds die too? Thank you for confirming this!
Post #246746 6th Mar 2014 8:50pm
No after the batteries are too gubbed to operate the camera they will still work the LED's for quite a while. 2008 MY Supercharged
Post #246811 7th Mar 2014 10:18am
adara
Thank you, seems like I’ll have to start the battery replacement procedure…
Post #246814 7th Mar 2014 10:44am
adara
Well I managed to replace the batteries, it took one hour and of course I broke the bottom tab while opening the case, so I thought maybe a picture of the cover would help future brave Venturecam owners in locating those tabs. I replaced the batteries with 6 Varta NiMH 800mAh and now it is working great! I must say though, the old batteries are still delivering 7.6V (but only 0.6A)...
Post #246927 7th Mar 2014 8:17pm
adara
This is weird, the camera is working, it can be viewed on the screen when its button is pressed, but it cannot be activated from the screen’s menu. And it is not charging. I got 12v at the cradle’s connector, I re-checked the wires in the cam, but it doesn’t charge when inserted, there is no progress bar and no green charging light. I am starting to believe this is the cause for the old batteries’ malfunction. What am I doing wrong?
Post #247161 8th Mar 2014 10:55pm
max
Italy 2007 Range Rover Vogue TDV8 Buckingham Blue
thanks 999, this is mine, tested on the car today : perfect !
a tip : with a little care, the tricky flat cable may be in place all along (as per pic)
many thanks
max
 2007 L322 TDV8 3.6 vogue
1981 Alfa Romeo Spider 1600
Post #262785 2nd Jun 2014 3:56pm
SO3isme
Does anyone think this item may be worth pursuing?
http://www.ebay.co.uk/itm/231276230116?_tr...EBIDX%3AIT
It does not appear to contain a thermistor.
Post #270534 13th Jul 2014 10:08am
crispy2
Australia 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Thanks Dave699, I had the same problem with no activity frm my Venturecam from my recently acquired 2007 S/C. Had a read of this, down to the supermarket for the same batteries, a bit of soldering last night, now in business. all lights working as they should, now just got to bond the two halves together then make sure it's all paired up and put to use.
Thanks for the photographic sequence to your instructions.
Regards
Pete.
Thumbs Up Thumbs Up
Bow down Bow down '07 4.2 S/C
'13 X3M
Post #294688 22nd Nov 2014 12:35am
TJH1985
Ive just done ours, we had 3 out of 6 dead cells in the AAA's.
Brought these from eBay: http://www.ebay.co.uk/itm/261710758578?_tr...EBIDX%3AIT
So we had less to solder, works a treat in the car now (2007) shows charging on the screen etc.
Thanks again,
Tom
Post #313416 18th Feb 2015 11:21am
Page 2 of 4 <1234>
