![]() | Home > In Car Electronics (L322) > Speedometer Needles Removal |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
didn't know that the needles had to come out....some on the forum have done this type of repair so i'm sure someone will come along and advise.. ... - .- -.
so i have found this,
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1550 ![]() ![]() |
I thought there is a little slotted tool to hold the shaft while the pointer is removed.
Patrickthier Member Since: 21 Aug 2016 Location: Dubai Posts: 11 ![]() ![]() ![]() |
Thanks,
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
The only problem I can see with this is, how do you re-calibrate the speedo and other gauges to read correctly when you re-assemble it all.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
The AK Speedo kit doesn't need the needles removing, it comes with a drill template and you drill through something instead!
Drill & Balls, not sure of the combination.
Gold Ranger Member Since: 31 Mar 2017 Location: East Midlands Posts: 33 ![]() ![]() ![]() |
i got the AK Speedo kit doesn't need the needles removing but you need patience and a steady hand
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
Any chance of a picture of the template? I got mine from ak a while back just not got round to stripping the dash |
as you can see by the template photo the actual hidden screw locations are indicated by the pen marks at the very top of the paper to get to some of the holes to drill you have to lift the front of your dial panel but dont put too much force on it and try not to catch it with the drill also the third hole along left to right is kinda awkward but doable |
Miserable Old Codger Member Since: 28 May 2018 Location: Cornwall Posts: 11 ![]() ![]() ![]() |
This might be useful for anyone replacing pixel ribbon in the future.
