Home > Maintenance & Mods (L322) > TDV8 Diff and Trans oil
Page 3 of 3 <123
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Changed the front and rear diff oils today..
- Rear diff oil wasn't that bad
- Front was ok too but the drain plug had greasy residue on it
The front diff drain and fill wasn't too bad.. I did the front in 15mins max. The transfer case oil change was most satisfying as the oil was pure black.. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #445215 20th Jul 2017 10:51pm
rar110
Interesting. How many km on the TC oil? ______________________________
Post #445217 20th Jul 2017 11:10pm
scotcruz
I have 100k on the clock and don't think it had been changed since new Current:
Past:
Post #445218 20th Jul 2017 11:12pm
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
2008 Range Rover TDV8 3.6 Transfer box capacity conundrum
Hi, I just drained and refilled front and rear diffs which took about a litre each. The transfer box drained about 1.3 Ltrs out and took about 1.6 litres to refill and get to the point where it dribbles from the fill hole.... the general consensus seems to be it should be about 0.95ltr and 1.0ltr from dry??? The car was dead level whilst doing the work so I’m puzzled, did later cars have a bigger transfer box or have I inadvertently gone n filled me glovebox and ashtrays with excess oil? Big Cry Can anyone throw some light on this? Thanks.
Post #482811 7th Jul 2018 10:27am
GGDR
I think the correct qty is 1.5 litres
. Cheers, Greg
Post #482814 7th Jul 2018 10:32am
nino_nino
1.5 l in my transfer box.
Nino,
Post #482816 7th Jul 2018 11:00am
Rapiscan
Phew glad to hear 1.5 ltrs the right amount. I wonder why it never seems mentioned in manuals etc, instead 0.95 ltrs quoted everywhere ad nauseum. I found some particles of metal in the bottom of the old oil... Big Cry
When I examined the magnetic drain plug off the front diff, it actually had a solid mound/ dome of hard metal particles about 4-5 mm thick on the end, I initially thought it was part of the plug but after attacking it with a screwdriver it all broke away! Astonishing how well that magnet has done its job and captured the crud!
Next job.....Auto gearbox! Shocked Cars done 125000 mls and I think my oil changes are it’s first..
Post #482817 7th Jul 2018 11:45am
Rapiscan
Attaching additional magnets to dumps and diff/ transfer box
Hi does anyone think attaching additional magnets to sumps/ diffs/ transfer box, adjacent to the drain plug would be beneficial? I currently have some exceptionally strong but small magnets I’m thinking of placing them as an additional help to capture suspended metal in oil.
Post #482827 7th Jul 2018 3:00pm
sako243
I'm pretty sure the diffs take a measured amount (which is why it's those quantities quoted in the manuals) not filled to the filler hole. If you've done that then you've overfilled it. Ed
Post #482883 8th Jul 2018 9:25am
GGDR
a great guide here in wiki section:
http://www.fullfatrr.com/forum/topic44954.html
. Cheers, Greg
Post #482884 8th Jul 2018 9:41am
Page 3 of 3 <123
