Home > Maintenance & Mods (L322) > TDV8 Diff and Trans oil
Page 2 of 3 <123>
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
Great web site.. Bow down Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443177 30th Jun 2017 8:41pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
but reluctant to my VIN code and it's up for everyone to see as it shows the last search Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #443178 30th Jun 2017 8:42pm
scotcruz
Picked up the oil from LR and changed the transfer case oil today.. Man that was satisfying.. dont think the oil had been changed since it was manufactured.
Will be changing the front and rear diffs tomorrow. Rear looks easy although access would be tight (even with the suspension at off road mode) as Im big.
Thr front doesnt look straight forward. Any hints and tips for the front one? Current:
Past:
Post #444276 11th Jul 2017 7:57pm
Keith A
United Kingdom 2009 Range Rover Vogue SE TDV8 Buckingham Blue
Haven't done the front on mine yet as it's a 14mm drain plug key, which I didn't have.
Should have arrived by the weekend so I'll let you know if there are any issues. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Mini Cooper Race Car Smile
Post #444284 11th Jul 2017 9:20pm
stu
yes the front is fiddly! i would suggest an extension and UJ on your ratchet or i used the 1/2" drive handle i got with my caravan motor mover as it has a gentle curve in it which gave enough clearance from the sub frame. Also when you crack the fill plug on the front, i used a 14 mm ratchet spanner on the allen key socket to turn it quicker and easier. My old fat fingers not so agile these days... Laughing Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #444323 12th Jul 2017 11:56am
scotcruz
cheers guys.. wish there was a video which showed the oil change as its always good to know what you are up against while u are under the car.
Waiting for my 14mm HEX socket so will report back. Current:
Past:
Post #444418 12th Jul 2017 11:28pm
stu
There are videos on you tube for diffs and trans box! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #444431 13th Jul 2017 7:07am
scotcruz
I found the transfer bix ones for 3.6 TDV8 but non for front diff.
Can you share any links mate? Current:
Past:
Post #444432 13th Jul 2017 7:23am
nino_nino
it is worth noting, when changing differentials and transfer box oil to undo the filler plugs before draining the oil. just in case
those plugs are stuck and you end up with empty difs Embarassed
Post #444453 13th Jul 2017 10:57am
Baltic Blue
Good tip Nino.
I hope you didn't learn that from a bad experience. 👍👍 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #444454 13th Jul 2017 11:05am
cam-tec-craig always banged on about that... Thumbs Up ... - .- -.
Post #444458 13th Jul 2017 11:32am
nino_nino
credit where credit is due , tks. stan Thumbs Up , i could not remember who it was. BB some things are best learned from somebody else experience Mr. Green
Post #444461 13th Jul 2017 12:55pm
Keith A
Easy to do (just done mine).
5x 10mm bolts to remove the undertray.
It's tight for the drain plug to get the plug key and 3/8" ratchet onto the plug owing to it fouling the chassis rail. Use an extension bar to clear the rail and the get to the ratchet/torque wrench when redoing.
The refill plug is easier to get to but needs an extension bar as well. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #444485 13th Jul 2017 4:53pm
scotcruz
did you undo the splash bar that's infront of the drain plug? Current:
Past:
Post #444509 13th Jul 2017 8:35pm
Keith A
Nope. Just the undertray to come off. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #444516 13th Jul 2017 9:40pm
Page 2 of 3 <123>
