Home > Maintenance & Mods (L322) > Bosch Aero Retrofit blades?
Page 4 of 5 <12345>
miggit
Thumbs Up You wont regret it, but you might wish you'd have done it earlier Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #374623 28th Feb 2016 1:25am
Sandyt
Weegie wrote:
When I got my FF the wipers clunked maddeningly as described. I fitted Bosch 808 nineteen months ago and they make no noise at all. Surprised that people are reporting noise. Wonder if it is down to adjustment of the arms rather than the blades?
Same here loud clunk when I bought it replaced with Bosch 808 blades and silence replaced again after a year again silence
never adjusted the arm only replaced the blades
Post #374639 28th Feb 2016 9:02am
The new ones will have to fit now!
Armed with an old bone handled flat bladed knife and a palette knife I took to the wiper fittings. Did as Miggit suggested and stopped the wipers at 12 o'clock, thus able to work on both from the drivers side, also dropped car to access height and used my little step stool. Placed an old mat on the windscreen to protect in the event of an arm slamming back on the screen (and it was needed!)
Decided to work on the drivers side wiper arm first, worked the knives in between the arm and the spigots on each side, then gave a sharp pull up and away from the wiper arm lengthwise. The fitting did already have a split in the casing, then came out in @ 5 pieces Laughing so the these new fangled wipers have got to fit now!
Same approach on the passenger side, a little easier with no aerofoil thingy in the way, but less to grab hold of to do the pull up and away! A little damage caused, with a split in the casing. As with most of the plastic on the FFRR it gets very brittle after 14 years.
Here is what came off
So, these new ones had better fit. As it happens, a good tight fit onto the arms. phew!
Reset the wipers and did a screen wash test, pretty good, reasonably quiet, and a good sweep.
Guess I need to buy another pair now for back up! .
Post #374655 28th Feb 2016 12:02pm
miggit
Whistle I did say do the passenger side first, then park at 12 o'clock and do the drivers..... that way you already know how they are supposed to come out!
I think that mine came out in 3 bits too, so your not the only one Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #374662 28th Feb 2016 1:03pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Hi Miggit,
Hows my wheel alignment tool coming on Whistle ?
Post #374681 28th Feb 2016 2:36pm
A drizzly morning so set off for work at normal. Started up the wipers with there new blades to be greeted by an eerie and uncanny silence as the aero blades swept back and forth. Not a sound or a squeak. I generally like to get some feedback from my mechanical devices so this was quite unnerving Laughing .
Post #375087 1st Mar 2016 1:01pm
miggit
It was the not shaking themselves to pieces that I found most alarming, oh, and being able to see I don't think that there's any bit of the screen that they don't wipe perfectly......... Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #375110 1st Mar 2016 5:23pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Just fitted a pair of these blades, nice and easy with the how to, took no mre than 10 mins both sides. As others, super quiet and great wipe. In case anyone in Oz is on the lookout, I got the from Aliexpress, US$ 13.99 shipped for the pair so much cheaper than just one std blade. A no brainer if you need new wipers.
http://www.aliexpress.com/item/Wiper-blade...32844.html just search for Range Rover wiper blades as cant get the link to go to the page 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #389783 2nd Jun 2016 3:20am
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
I also just fitted a pair of these blades, which was nice and easy with Miggit's how to guide Bow down , took no more than 10 mins both sides. Thumbs Up
Will see how they perform in the expected thundershowers later.
Post #390541 7th Jun 2016 1:59pm
I've had mine on since the winter and have been really impressed, they're still very quiet, a massive improvement on the old Bosch 808 blades. I won't be going back to them. Discovery 4 HSE
Post #390563 7th Jun 2016 4:22pm
TimP
England 2005 Range Rover Vogue Td6 Java Black
Just fitted these http://go.hubnuts.uk/?id=106254X1563338&am...mp;xtz=-60
and really impressed.
Simplest fit - minutes/ seconds for both sides (and I am a renowned numpty Rolling Eyes )- and far superior to standard originals and Bosch 808s I replaced. JLR should fit this type as standard.
Post #443820 7th Jul 2017 3:48pm
nice find Tim... Thumbs Up ... - .- -.
Post #443822 7th Jul 2017 3:57pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
ordered a set Smile 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #443831 7th Jul 2017 4:30pm
b348xyx
http://www.ebay.co.uk/itm/HQ-Windscreen-Wi...2749.l2649
Well the wipers arrived, easy to fit but had to bend one the end bits a little inwards.
Will let you know how they perform on the road and rain. look nice though
Post #444334 12th Jul 2017 2:11pm
b348xyx
Anyone know if there’s an aero blade for the rear ? 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #444338 12th Jul 2017 2:45pm
Page 4 of 5 <12345>
