Home > Technical (L322) > Reduced Engine performance |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
Below is the output of the gap tool
8th Jul 2017 4:39pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
My initial thoughts are duff battery. |
8th Jul 2017 4:42pm |
Interesting thanks will stick it on the cteck to see what it says tbf most of the journeys are short.... |
8th Jul 2017 4:47pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Have you checked your Aux Coolant Pump is wired the correct way round?
8th Jul 2017 10:30pm |
Maybe a fault codes should be logged, perhaps I have the gap tool not setup right, but you would think if it triggers a warning on the dash then it should also log a code |
8th Jul 2017 10:52pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
If you plug in your IID, go to faults, open the advanced menu, make sure that PENDING, CONFIRMED AND MIL REQUESTED are ticked, click on save and take it from there. You should get engine faults etc from that.
9th Jul 2017 3:30pm |
Sorry for the late 'reply, charged up the battery w as only on 3 on ctek, not seen the message since, did have a random low coolant message come up but checking under bonnet it's on the Mac line, got to love land rover electrics |
29th Jul 2017 6:01pm |
