Home > Technical (L322) > Gearbox options...
Danwilderspin
Gearbox options...
Whilst mine is ok now if it ever does fail I know the boxes on the m62 can barely handle the power thrown at them... is there anyway to put the 6 speed box or something in it and have it all working nicely?
Post #443330 2nd Jul 2017 6:48pm
stu
Can you not fit an updated torque converter? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443344 2nd Jul 2017 8:23pm
RRPhil
The 6HP26 was never designed to physically mate to the M62 engine nor the NV225 transfer box and the electronic/control integration issues would be insurmountable, in my opinion. It would be far easier & cheaper to sell your car and buy a later 6-speed model than to replace the 5-speed box with a 6-speed unit.
Although the limitations of the infamous GM 5L40-E transmission used in the TD6 are very well known, the ZF 5HP24 used in your V8 is less problematic and issues are mainly confined to two areas – the B-clutch hub/C-clutch drum axial bearing failure and the torque converter lock-up clutch vibration.
Regarding its torque capacity, although the 5HP24 was originally specified for 420Nm, and the L322 M62 engine produces 440Nm, the same transmission with identical internal running gear was later used for the 4.6is BMW X5 which produced 480Nm and the 4.8 litre Alpina E39 B10 V8S & E52 Z8 which produced 510Nm. These higher torque applications used a 280mm diameter torque converter rather than the 260mm unit.
By the way, the 6-speed isn’t without its issues either (solenoids, stator bush wear, etc.)
Phil
Post #443368 3rd Jul 2017 10:28am
Danwilderspin
Hi - so if you fitted the 280mm torque converter it could handle extra beams?
Post #443687 5th Jul 2017 9:13pm
RRPhil
ZF also added an extra friction & steel plate to the D-clutch to increase its capacity but basically, yes, that it. The radial stiffening ribs in the bellhousing are machined to accommodate the bigger converter.
Phil
Post #443706 6th Jul 2017 11:41am
