Home > Technical (L322) > Gearbox options... |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
Can you not fit an updated torque converter? Current: TDV8 (3.6) RRS HSE
2nd Jul 2017 8:23pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
The 6HP26 was never designed to physically mate to the M62 engine nor the NV225 transfer box and the electronic/control integration issues would be insurmountable, in my opinion. It would be far easier & cheaper to sell your car and buy a later 6-speed model than to replace the 5-speed box with a 6-speed unit.
3rd Jul 2017 10:28am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Hi - so if you fitted the 280mm torque converter it could handle extra beams? |
5th Jul 2017 9:13pm |
ZF also added an extra friction & steel plate to the D-clutch to increase its capacity but basically, yes, that it. The radial stiffening ribs in the bellhousing are machined to accommodate the bigger converter.
6th Jul 2017 11:41am |
