Home > In Car Electronics (L322) > How hard is running a cable into the upper tailgate?
GGDR
Hi team,
I need to run a cable into the upper tailgate to fit my rear dashcam.
I think there are two gaiters / bellows which I'll need to get it through but any tips on how to get the trim off either side would be greatly appreciated.
. Cheers, Greg
Post #442531 24th Jun 2017 9:41am
stick the dashcam on the tailgate glass and then tuck the cable into the tailgate trim...leave a bit extra loose so when you open the tailgate it wont stretch... ... - .- -.
Post #442538 24th Jun 2017 10:23am
GGDR
Thanks Stan! I want to get it through the gaitor. Just unsure how to get into that... Cheers, Greg
Post #442540 24th Jun 2017 10:37am
the rubber gaiter?...you dont....
cam on glass. then link and hide the cable in the frame trim... ... - .- -.
Post #442545 24th Jun 2017 11:00am
The easiest way would be to pull out the upper end of the gaiter from the body , feed the cable through from the open end down into the tailgate, poke a length of cable into the space above the roof headlining and the refit the gaiter. The gaiter fits just like a grommet. You can then fish for the length of cable you poked into the headlining with a length of wire or similar with with the end formed into a hook. Simples Thumbs Up
Post #442546 24th Jun 2017 11:01am
GGDR
stan: yes your technique is good to tuck it in. But I need to get it from the hinged door, through the gaiter (like the other cables) and into the main car body. Do you have a rear cam? If so how do you get your cable to cross the hinged door to the fixed main body?
nicedayforit: great idea ill try that.
BEST FORUM EVER!
Thanks chaps!
. Cheers, Greg
Post #442548 24th Jun 2017 11:09am
this my setup, with the cable tucked into the trim,
Post #442567 24th Jun 2017 2:12pm
