![]() | Home > In Car Electronics (L322) > How hard is running a cable into the upper tailgate? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
stick the dashcam on the tailgate glass and then tuck the cable into the tailgate trim...leave a bit extra loose so when you open the tailgate it wont stretch... ... - .- -.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Thanks Stan! I want to get it through the gaitor. Just unsure how to get into that... Cheers, Greg
the rubber gaiter?...you dont....
The easiest way would be to pull out the upper end of the gaiter from the body , feed the cable through from the open end down into the tailgate, poke a length of cable into the space above the roof headlining and the refit the gaiter. The gaiter fits just like a grommet. You can then fish for the length of cable you poked into the headlining with a length of wire or similar with with the end formed into a hook. Simples |
stan: yes your technique is good to tuck it in. But I need to get it from the hinged door, through the gaiter (like the other cables) and into the main car body. Do you have a rear cam? If so how do you get your cable to cross the hinged door to the fixed main body?
this my setup, with the cable tucked into the trim,
