Home > Maintenance & Mods (L322) > Fitting new battery.
dan_uk_1984
47p2 wrote:
dan_uk_1984 wrote:
You may find your sunroof has lost its "home position" next time you use it. Hold the close direction for 15 seconds to re-initialise it.
Dan
God how I love my basic SE....no sunroof so one item less (of the many many many things) to worry about Thumbs Up
By that logic perhaps you should have a Defender? They have no equipment to break!
Post #42924 20th Dec 2010 7:56pm
Not a bad idea Dan Thumbs Up
Post #42927 20th Dec 2010 8:02pm
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Dan Thanks for that, because of the weather that was the last thing i would of thought about.
But now you have told me i will be out first thing in the morning to set my roof.Once again thanks. Thumbs Up
Post #42967 20th Dec 2010 9:56pm
SteveMFr
Site Sponsor
JW911 wrote:
Someone step in if I'm wrong but I'm sure I was told that the negative lead has an explosive charge on it to disconnect the electrics in case of impact. If not, I'm possibly confusing it with something else but if so, be ****** careful!! Shocked
It's not a hand grenade! Rolling with laughter (2 nerdly engineers having a conversation during vehicle development: We'll detonate the battery and make sure there is no power left to cause a fire...) Rolling with laughter
If it went off, you'd hear a 'pop' and the terminal would jerk in your hand. That would be about it. On the + terminal, BTW (as Joe already said).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #42999 21st Dec 2010 7:47am
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I can count the number of times I've been told that on the fingers of both hands. Nine. Laughing 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #43012 21st Dec 2010 9:18am
piecost76
Just changed the battery on mine & went for the Bosch 110AH one from Euro Car Parts!
Whole process took about 40 mins, incl waiting for everything to shut down.
Now I have the "Air Suspension Inactive" warning although it all works fine???
Anyone got any suggestions?
Thanks! Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #44205 2nd Jan 2011 1:22pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Try turning the steering full lock to lock- either that or driving for 5-10 minutes should also clear it.
Post #44207 2nd Jan 2011 1:31pm
piecost76
Thanks, did the steering thing, but nothing noticeable happened - do I just go from centre to Left full then Right full? Should I see some lights or hear some beeps etc?
Am popping out in about 1 hr so will see what happens then! Quis custodiet ipsos custodes?
15 MY 110 XS USW
Post #44209 2nd Jan 2011 1:44pm
turning the steering from left to right only sets the steering parameters...hopefully the error will go out once the suspension goes up and down a few times... ... - .- -.
Post #44211 2nd Jan 2011 1:51pm
dan_uk_1984
The steering parameters are for the DSC and if there is a "fault" with the DSC then the EAS locks in "lower than standard" height. Not being able to tell which way the steering is turning is classed as a fault...
So turn lock to lock, then the DSC light will go out. Then once thats gone out a cycle of the ignition "should" clear the EAS warning.
Post #44213 2nd Jan 2011 1:58pm
yea, what he ^^ said... Wink ... - .- -.
Post #44215 2nd Jan 2011 2:02pm
piecost76
All sorted now, thanks Guys Thumbs Up Quis custodiet ipsos custodes?
15 MY 110 XS USW
Post #44272 2nd Jan 2011 11:09pm
