Home > Maintenance & Mods (L322) > Fitting new battery. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 |
just done one and yes it is a tight squeeze but easily diy...make sure you put the bonnet in service mode and have a stool handy to stand on.. ... - .- -.
18th Oct 2010 10:25am |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
how do you put the bonnet into "service mode" scarey? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
18th Oct 2010 10:45am |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
Tip: Its easier to do with 2 people.
18th Oct 2010 11:04am |
open bonnet, unclip the two bonnet supports at the bottom, these can sometimes be done by hand...lift the bonnet to vertical and on each side there is a sliding bit of metal that clips onto the support mechanism to keep the bonnet upright...
18th Oct 2010 11:05am |
Thanks guys, I'm sure there are others who were wondering too! Maybe it should have a "sticky" at the maintenance and modification section? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
18th Oct 2010 12:20pm |
td6 vogue Member Since: 31 Dec 2009 Location: essex Posts: 93 |
Yeap thats what i wondered, if the bonnet could open up more. Thanks for the info. |
18th Oct 2010 12:28pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
http://www.youtube.com/user/elpeede#p/a/u/2/8Hq6Ox86xho
18th Oct 2010 12:54pm |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 250 |
Someone step in if I'm wrong but I'm sure I was told that the negative lead has an explosive charge on it to disconnect the electrics in case of impact. If not, I'm possibly confusing it with something else but if so, be ****** careful!! 2021 3.0 P400 Vogue
18th Oct 2010 9:46pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
Link to Battery Disconnection howto
18th Oct 2010 9:51pm |
Thanks for that. Mind your fingers. 2021 3.0 P400 Vogue
19th Oct 2010 7:48am |
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 |
Thanks guys,after reading this Topic i pluked up courage and fitted my new Battery this morning.
20th Dec 2010 4:37pm |
result.. ... - .- -.
20th Dec 2010 4:44pm |
You may find your sunroof has lost its "home position" next time you use it. Hold the close direction for 15 seconds to re-initialise it. Dan |
20th Dec 2010 6:33pm |
God how I love my basic SE....no sunroof so one item less to worry about |
20th Dec 2010 7:33pm |
