Home > Maintenance & Mods (L322) > Fitting new battery. |
By that logic perhaps you should have a Defender? They have no equipment to break! |
20th Dec 2010 7:56pm |
Not a bad idea Dan |
20th Dec 2010 8:02pm |
It's not a hand grenade! (2 nerdly engineers having a conversation during vehicle development: We'll detonate the battery and make sure there is no power left to cause a fire...) If it went off, you'd hear a 'pop' and the terminal would jerk in your hand. That would be about it. On the + terminal, BTW (as Joe already said). RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
21st Dec 2010 7:47am |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 229 |
I can count the number of times I've been told that on the fingers of both hands. Nine. 2012 4.4 TDV8 Westminster 2007 3.6 TDV8 Vogue - gone! 2003 V8 HSE (LPG) - gone! 2018 F-Pace 25t Portfolio 1974 LR Series III Lightweight FFR 2014 BMW 640i Gran Coupe |
21st Dec 2010 9:18am |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 |
Just changed the battery on mine & went for the Bosch 110AH one from Euro Car Parts!
2nd Jan 2011 1:22pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
Try turning the steering full lock to lock- either that or driving for 5-10 minutes should also clear it. |
2nd Jan 2011 1:31pm |
Thanks, did the steering thing, but nothing noticeable happened - do I just go from centre to Left full then Right full? Should I see some lights or hear some beeps etc?
2nd Jan 2011 1:44pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
turning the steering from left to right only sets the steering parameters...hopefully the error will go out once the suspension goes up and down a few times... ... - .- -.
2nd Jan 2011 1:51pm |
The steering parameters are for the DSC and if there is a "fault" with the DSC then the EAS locks in "lower than standard" height. Not being able to tell which way the steering is turning is classed as a fault... So turn lock to lock, then the DSC light will go out. Then once thats gone out a cycle of the ignition "should" clear the EAS warning. |
2nd Jan 2011 1:58pm |
yea, what he ^^ said... ... - .- -.
2nd Jan 2011 2:02pm |
All sorted now, thanks Guys Quis custodiet ipsos custodes?
2nd Jan 2011 11:09pm |
