Home > Technical (L322) > Front door card won't come off. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
18th Jun 2017 5:46pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
Joe,
18th Jun 2017 10:14pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I've had both of mines off countless times and it's always been a pain refitting and getting it to fit as it was. I had excact the same issue with the window strips. I ended up buying a load of those yellow popper clips and replaced them as they go flimsy. Door cards sit perfect now.. |
18th Jun 2017 10:36pm |
18th Jun 2017 10:37pm |
Mine are mostly white clips, except for one black one just below the mirror which broke up. That coupled with the cracked lip near the window switches has left it less than 100%. I will have another go at fitting it with some new clips and maybe try to glue the cracked plastic. Is there a website where I can look up the clip part numbers? The videos of removal make me laugh, it really isn't quite as easy as they would have you believe. |
18th Jun 2017 11:31pm |
Eyc000360 is the part number for the clips. 👍 |
19th Jun 2017 7:55am |
Thanks. Are they all the same? I seem to have one different on near the mirror. |
19th Jun 2017 9:34pm |
I have the same. I haven't touched that one tbh.im sure the other ones are used in all l322's. Mines had crumbled and there was no way they could hold the door card on tightly...
19th Jun 2017 10:47pm |
