![]() | Home > Technical (L322) > Front door card won't come off. |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
Joe,
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I've had both of mines off countless times and it's always been a pain refitting and getting it to fit as it was. I had excact the same issue with the window strips. I ended up buying a load of those yellow popper clips and replaced them as they go flimsy. Door cards sit perfect now.. |
Mine are mostly white clips, except for one black one just below the mirror which broke up. That coupled with the cracked lip near the window switches has left it less than 100%. I will have another go at fitting it with some new clips and maybe try to glue the cracked plastic. Is there a website where I can look up the clip part numbers? The videos of removal make me laugh, it really isn't quite as easy as they would have you believe. |
Eyc000360 is the part number for the clips. 👍 |
Thanks. Are they all the same? I seem to have one different on near the mirror. |
I have the same. I haven't touched that one tbh.im sure the other ones are used in all l322's. Mines had crumbled and there was no way they could hold the door card on tightly...
