Home > Technical (L322) > Broken drivers door mechanism?
RRR207
Switzerland 2005 Range Rover Autobiography 4.4 V8 Zambezi Silver
After a few weeks of a stiff door handle I went to get into the RR yesterday & nothing happened!
I pulled the door handle, there was some immediate resistance & then it went loose. Further attempts to open the door were unsuccessful. The handle will move freely but it's obvious it's not attached to anything! The door can be opened as normal from inside.
I'm assuming the external release cable has snapped?
1. Before I order a new cable is there anything else it might be?
2. Genuine or aftermarket? Cost difference is minimal £27 v £40
3. Is it a dealer, RR specialist, any competent mechanic or DIY job to replace it?
Thanks in advance Thumbs Up Current - RRV Autobiography 4.4V8 2005
Modifications - 20" Westminster Alloys with Grabber AT's. BRC LPG Conversion.
Previous- RRC 3.9V8/91. RRC 4.2V8/94 LSE Softdash. RRC 2.5tdi/94. RRC 2.5tdi/91. RR p38 2.5DHSE/01, Disco2 2.5td5/03, Disco4 2.7tdv6/10 ..... all gone.
Member of the RangeRoverRegister & Wessex4x4Response (Bristol Team)
Post #439184 21st May 2017 8:39pm
mjdronfield
My Indy did mine on my TD6..... I understand if you get it wrong, you can't open the door from outside or inside..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #439185 21st May 2017 8:43pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
I had same prob. fitted aftermarket cable no probs so far . its a pretty simple fix just a bit fiddely getting interior handle coupled up but after a few attempts you will be expert . give everthing a good oil when you are in there . good luck
Post #439186 21st May 2017 8:49pm
mjdronfield
There are some videos on YouTube... this is one of a few. Might be one of a number for the complete job.
Will give you an idea whether you want to tackle it yourself.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #439189 21st May 2017 9:06pm
^^^ 0/10 for camera work .
Post #439205 21st May 2017 10:41pm
RRR207
Cheers Thumbs Up
My local specialist independent will be fitting the non-genuine cable asap. Current - RRV Autobiography 4.4V8 2005
Post #439284 22nd May 2017 8:28pm
Dolphinboy
@RRV207
Who did you use in bristol? Mine's just gone. how much was it (inc. part?)
Post #441759 17th Jun 2017 10:07am
sako243
Dolphinboy it's quite a simple job, took me about 15 minutes in total.
Opened the door from inside, removed the door card (plenty of guides online). After that the Bowden cable simply clips into place, it is a little fiddly particularly if you have big hands. Ed
Post #441768 17th Jun 2017 12:08pm
RRR207
I used Downfield Garage, Downfield Rd, Clifton .... 0117 9737355
They're a little indie that I've used loads of times over the years. They aren't a LR specialist but they know what they're doing, it's staffed by two genuine mechanics not motor vehicle technicians if you know what I mean?
Used aftermarket part for about £27 delivered & fitting was an hours labour.
There is an airbag in the door along with all the other stuff so despite watching the videos I decided not to try it myself. Current - RRV Autobiography 4.4V8 2005
Post #441772 17th Jun 2017 12:14pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
I have the broken cable problem too.
What's the procedure for disarming the airbag? Battery disconnected for 30 minutes?
Post #441832 18th Jun 2017 12:11am
sako243
Yes but doesn't need to be as long, negative first. Ed
Post #441854 18th Jun 2017 8:49am
