![]() | Home > Technical (L322) > Broken drivers door mechanism? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
My Indy did mine on my TD6..... I understand if you get it wrong, you can't open the door from outside or inside..... 2011 Range Rover Vogue SE 4.4 TDV8
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
I had same prob. fitted aftermarket cable no probs so far . its a pretty simple fix just a bit fiddely getting interior handle coupled up but after a few attempts you will be expert . give everthing a good oil when you are in there . good luck |
There are some videos on YouTube... this is one of a few. Might be one of a number for the complete job.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
^^^ 0/10 for camera work .
RRR207 Member Since: 27 May 2016 Location: Basel Posts: 49 ![]() ![]() ![]() |
Cheers |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
@RRV207
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Dolphinboy it's quite a simple job, took me about 15 minutes in total.
I used Downfield Garage, Downfield Rd, Clifton .... 0117 9737355
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
I have the broken cable problem too.
Yes but doesn't need to be as long, negative first. Ed |
