Home > Technical (L322) > Rear washer non return valve
dirtymonkey38
Hi, may be a daft question. Should you be able to blow through the non return valve when its off the car? Im getting no water coming out through the rear jet when activating the rear washers. I would have expected to be able to blow through it like i can on the fish tanks non return valve but cant. Had the valve in bits but all looks ok to me. If its faulty would anyone know the part number and/or price?
Offending article below:
Post #440984 8th Jun 2017 5:26pm
dirtymonkey38
2011 4.4 TDV8 Autobiography by the way.
Post #440985 8th Jun 2017 5:27pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Should be able to blow through it in one direction only.
Post #440986 8th Jun 2017 5:32pm
dirtymonkey38
Thats what i thought. Membrane must be knackered then, although it looks ok.
Post #440988 8th Jun 2017 5:35pm
hamlet
You could try joining the two pipes where you removed the NRV together and see if you get water then.
Post #440990 8th Jun 2017 5:38pm
dirtymonkey38
I tried a spare one off the fish tank but the pipes are wider than the valve will allow so it popped off quite easily. Water definitely reaches the valve as It went all over the towel in the boot I had on hand when it popped off. will have to see if i have anything i can connect the two pipes together to bypass the valve.
Post #440992 8th Jun 2017 5:45pm
Clivefog
Just get a new valve - 65p in local car part place - sorted mine out.
Post #440993 8th Jun 2017 5:55pm
hamlet
If you can't find anything to connect the two pipes try getting a mouthful of water and blowing it through the pipe to washer end yourself.
Don't use a mouthful of beer...........that's just a waste........ Laughing
Post #440994 8th Jun 2017 5:59pm
any NRV will do. yet another weak spot, but an easy fix. There is nothing that can't be fixed with a hammer😜😜
Post #440995 8th Jun 2017 6:08pm
dirtymonkey38
Defiantly the non return valve. Cant blow anything through it, tried really hard and I backfired sending the dog scattering across the kitchen after she gained traction on the laminate flooring. Been back out to it while its stopped raining and the tube is long enough to reach the connector on the wiper motor, retried and it worked, although it was a little dribble. Poked a pin into the jets and tried again and now works much better so just need to get a new valve from a motor factors tomorrow and blow it all out with the compressor.
On another note, are the jets direction adjustable with a pin? Didn't get a good look as the wiper arm wasn't in the best position and my slippers were slowly filling with water from the puddle I was stood in courtesy of the rubbish weather this week. 2011 RR Autobiography 4.4 TDV8
Post #441002 8th Jun 2017 6:50pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Hmmm ... wondering if this is the issue with mine, as I too have no rear wash. Sad
Whereabouts is the NRV fitted?? Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #441004 8th Jun 2017 6:58pm
NRV is in the top of the upper bot lid.
you have to remove the upper trim piece on the inside. its a fiddly bit of plastic to get back on, you have to make sure you don't bend/break the tangs on the plastic. There is nothing that can't be fixed with a hammer😜😜
Post #441012 8th Jun 2017 7:19pm
Spooky
Cheers. I'll have a check later. Thumbs Up Regards,
Mick
Post #441073 9th Jun 2017 3:35pm
dirtymonkey38
All sorted. Picked up a non return valve from a local motor factors and fitted. Unfortunately it was hopeless and leaked everywhere, as if it couldn't cope with the pressure going through it. Tried all sorts to get it to work, wrapping it with plumbers ptfe tape etc but couldn't stop it leaking. Rang a land rover dealer and there parts department told me the valve doesn't come separately and is part of the hose, at a cost of just over £30. Took myself off to rs components to see if there was anything suitable to do the job and had no luck there. Thought I would end up ringing back the stealership to order the hose however I live close to boltonbits and called in on my way past and hey presto, washer jet non return valve £2. Fitted tested and no leaks, happy days. Back home and refitted the trim.
Taking the trim panel off, I started in the middle to get it started. Pulled slightly (with a bit of force) to release the clips without coming all the way out, used an old hand towel (bit of a sharp edge on the trim and helps to keep dirty marks off it) to slide across the bottom edge towards the right hand side till it got tight and did the same pulling away without going all the way, and finally repeated the same on the left hand side edge, keeping a bit of pulling pressure on the middle to stop it all popping back into place. Once clips were started gave it sharp tug on the right hand side, came out with a right cracking noise and thought i had bust the trim panel, however it was only the noise of the plastic popping off the other trim that runs vertically down the side of the glass. They fit in to each other. Popped the middle bit out fully to get a bit more tension on the remaining clips on the left. One last sharp tug and it was free, no clips broken.
Taking the trim off needs a firm hand and pulling out straight, you don't have much side to side movement available as this is what will cause the clips to break. Slow and steady and you shouldn't move the receiving clips inserted into the body work which should allow for easier re-installation of the trim panel. Only took 2 minutes to put it all back together. 2011 RR Autobiography 4.4 TDV8
Post #441091 9th Jun 2017 6:04pm
Spooky
Nice work! Thumbs Up
Got mine sorted, too. Turned out that the nozzles were blocked, as the water jetted out of the hose happily. Very Happy Regards,
Mick
Post #441097 9th Jun 2017 6:48pm
