![]() | Home > Technical (L322) > Rear washer non return valve |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 ![]() ![]() ![]() |
2011 4.4 TDV8 Autobiography by the way. |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Should be able to blow through it in one direction only. |
Thats what i thought. Membrane must be knackered then, although it looks ok. |
You could try joining the two pipes where you removed the NRV together and see if you get water then. |
I tried a spare one off the fish tank but the pipes are wider than the valve will allow so it popped off quite easily. Water definitely reaches the valve as It went all over the towel in the boot I had on hand when it popped off. will have to see if i have anything i can connect the two pipes together to bypass the valve. |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Just get a new valve - 65p in local car part place - sorted mine out. |
If you can't find anything to connect the two pipes try getting a mouthful of water and blowing it through the pipe to washer end yourself.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
any NRV will do. yet another weak spot, but an easy fix. There is nothing that can't be fixed with a hammer😜😜
Defiantly the non return valve. Cant blow anything through it, tried really hard and I backfired sending the dog scattering across the kitchen after she gained traction on the laminate flooring. Been back out to it while its stopped raining and the tube is long enough to reach the connector on the wiper motor, retried and it worked, although it was a little dribble. Poked a pin into the jets and tried again and now works much better so just need to get a new valve from a motor factors tomorrow and blow it all out with the compressor.
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
Hmmm ... wondering if this is the issue with mine, as I too have no rear wash. |
NRV is in the top of the upper bot lid.
Cheers. I'll have a check later. |
All sorted. Picked up a non return valve from a local motor factors and fitted. Unfortunately it was hopeless and leaked everywhere, as if it couldn't cope with the pressure going through it. Tried all sorts to get it to work, wrapping it with plumbers ptfe tape etc but couldn't stop it leaking. Rang a land rover dealer and there parts department told me the valve doesn't come separately and is part of the hose, at a cost of just over £30. Took myself off to rs components to see if there was anything suitable to do the job and had no luck there. Thought I would end up ringing back the stealership to order the hose however I live close to boltonbits and called in on my way past and hey presto, washer jet non return valve £2. Fitted tested and no leaks, happy days. Back home and refitted the trim.
Nice work! |
