Home > Maintenance & Mods (L322) > "CHECK COOLANT LEVEL" - Dashboard warning |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
You can either replace the sensor (without having to drain the coolant) or replace the expansion tank complete with sensor.
5th Jun 2017 4:31pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 |
I Used to get this on an 02 TD6 but only after a period of high speed driving. I lived with it and nothing bad happened.
5th Jun 2017 4:43pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 |
is the coolant you are using ready mixed?
5th Jun 2017 5:44pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
i changed the tank a few weeks ago as was the same and only about 40 quid, easy to do and saved about 100 quid from a garage as its a common issue apparently _____________________________________________________
6th Jun 2017 3:56pm |
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 |
I had fitted a new expansion tank in February after the original and first replacement sprung a leak. The level is always full or near full whenever I check before driving so it must have been the sensor and the ready-mixed consistency. Anyway, had some rear suspension parts replaced by my Paris Land Rover trained mechanic and he has reset the fault code so the message has disappeared. There no drips under the vehicle, so I reckon the problem has been rectified.
7th Jun 2017 2:16pm |
The message has returned and is refusing to go away! I changed the coolant yesterday to one that is dark green but was told by someone here that the colour is only a dye and that whether you buy blue, pink or green it is all the same strength. Changing the expansion tank has been suggested, so I will probably order one of those when I order a couple of interior trim panels. It is really annoying as the level does not seem to drop and I have to check every day, just to be on the safe side.
15th Jul 2017 6:57am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
I have read many times that the coolant concentration if low can set off the warning. I am yet to read any explanation as to how a simple magnetic switch not in contact with the fluid can be effected by the concentration of the coolant. It is surely activated by a magnet in the float? The float sinks and sets off the warning.
15th Jul 2017 9:15am |
Just in case anyone wants to test their magnetic reed coolant level switch, you just need a magnet and a continuity tester / multi meter. 2007 TDV8 VSE
16th Jul 2017 12:50am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 |
The only way the system could do that is if the float acted like a hydrometer float and was affected by the relative density of the coolant. Does a correct mix have a sufficiently different density to that of plain water? I'd have thought that it would have to be significant for the float to be so affected. Merely driving on bumpy roads would otherwise set the alarm off. It sounds like a furphy* to me. * Aussie term - see https://en.wikipedia.org/wiki/Furphy Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
16th Jul 2017 4:12am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 |
Measuring specific gravity is affected by temperature. Quite substantial changes can occur. I doubt that the system in the RR is a hydrometer.
16th Jul 2017 4:45am |
Good point weegie. Ron B. VK2OTC
16th Jul 2017 9:16am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Steve, i posted this in a different tread.
8th Aug 2017 3:18pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
20th Mar 2020 11:10am |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 |
Received the "Low coolant level"message today while coolant level is correct.Do one clean the bottle as Nino did or do you replace the bottle?Where do one get the correct anti-freeze....from LR?
23rd Aug 2020 6:28pm |
