Home > Maintenance & Mods (L322) > Help needed with RANGE ROVER SCL / ESL / ELV EMULATOR
smiler289
Hi I have the dreaded steering column lock failure. So I bought a RANGE ROVER SCL / ESL / ELV EMULATOR. Fitted it no probs. Keys turns everytime but engine will not turn over. The site I bought it from says this:
HINT - if key turns, but there is no start allowed: find wire directly coming from EWS to ESL (P/N signal, wired through ESL) and short it to +12v. Or recode EWS to ignore this wire (on most cars it is ignored by default).
Can anyone please help with this so I know what am looking for. Obviously my EWS does not ignore this wire by default. I have an 02 plate l322 4.4 v8.
Any help will be greatly appreciated
James
Post #439684 26th May 2017 11:13am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
the EWS ECU is for the immobiliser chip in key, it can be found driver side next to the gear lever, maybe find a pin out diagram some where for the correct one
Post #439688 26th May 2017 12:29pm
smiler289
Hi. Thanks I thought it was around that area. A white box isn't it? Presume I will have to take all the trim apart around the gearstick to see it?
Cheers
Post #439690 26th May 2017 12:39pm
smiler289
Found a diagram. There are three wires however that go to the steering wheel, now I need to workout which one needs to be wired permanently to 12v
Post #439692 26th May 2017 12:54pm
smiler289
Do you think by them saying "P/N signal wired through esl.. ." They mean park /neutral?
Post #439695 26th May 2017 1:04pm
Lukie
yes white box, you need to remove the cubby hole, down to the gear lever leather, it's a white box drivers side, loosen the 1 bolt you can see, you can then lift it out without fully removing the bolt, from memory you lift it and pull it towards back of the car
the P/N wire for park nutrual seems reasonable maybe send them an email to confirm
Post #439703 26th May 2017 2:06pm
smiler289
Contacted the seller. Asked them if they could tell me which wire I am looking for and does p/N stand for park/neutral.
They told me:
Yes. Because p/n is wired through esl...
You can download some wiring diagrams too - just follow links in item description."
So am still not quite sure which wire am looking for but I think it must be the park neutral wire
Post #439714 26th May 2017 4:21pm
smiler289
This is one of the diagrams on the site. Do you think it is pin 6 that I need to feed 12v to? Am getting awfully confused.
Post #439726 26th May 2017 5:59pm
Lukie
I will have to stop at this point as I can't be certain and would hate for you to.follow my advise then brake something further
Is yours a td6?
Post #439799 27th May 2017 4:54pm
smiler289
No it's a v8. Something just doesn't add up with what information I have been given. Maybe something has been lost in translation.
Post #439801 27th May 2017 4:57pm
AusRR
Australia 2003 Range Rover HSE 4.4 V8 Zambezi Silver
Hey Smiler, did you have any success with the emulator?
Post #442623 25th Jun 2017 3:05am
smiler289
Hi. No I haven't. The emulator will let me turn the key everytime but not start the car. I have had the car into a land rover specialist recently, infact they had it for two weeks because it had so many faults that needed repairing and its got to go back for the air conditioning because the regassed it but must of not tested it because it doesn't blow cold. Fuel gauge doesn't go all the way to the top either but I can live with that for now.
I had them look into reprogramming the ecu to ignore the p/n wire but they said they couldn't do it and wouldn't put a live 12v feed to the actual wire because they were afraid of causing damage to the ecu. I still don't know which wire it is am looking for.
There must be someone out there that has used this same emulator.
Post #442637 25th Jun 2017 8:20am
AusRR
Im having the same issue as you smiler, I emailed them about running 12v to ews to esl and got the following response:
Make sure that + 12V power supply properly, already with key in ON position on dash.
After installing emulator, and before starting the car, clear all errors with diagnosis.
will check there arent any errors with allcoms but cant imagine this will help
Post #442642 25th Jun 2017 9:10am
smiler289
"Make sure that + 12V power supply properly, already with key in ON position on dash.
After installing emulator, and before starting the car, clear all errors with diagnosis"
So what are they actually saying? That we need to provide this extra 12v supply to the p/n wire whilst the ignition key is on but don't try to start the car and do it before plugging in the emulator and we must make sure there are no errors?
Post #442646 25th Jun 2017 9:41am
ParabolD
Czech Republic 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hello guys. Did you figure out the emulator? My is on the way, so I want just to be ready...Thank you.
Post #454179 16th Oct 2017 9:57am
