Home > Technical (L322) > live values on Steering sensor please |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Where are the live values for the steering angle sensors on the IID Tool, can't find anything for them, just been out and plugged my IID in to read them, but there's no mention in the live data menus. |
18th May 2017 11:15am |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I'm home at tea time .. if you haven't had an answer by then I will post up mine 👍 |
18th May 2017 11:51am |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
scroll down on the Live Values, then select Live Values > Live Values ECU > SASM - STEERING Angle > Steering Angle degrees
18th May 2017 11:54am |
Hmm, couldn't find that option on my BT IID Tool, will have another look later and may need to get the IID updated |
18th May 2017 2:40pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
this is what I have, center, full right, full left .
18th May 2017 3:27pm |
And mine. Left then right
18th May 2017 7:42pm |
Thank you all for doing that for me, it's much appreciated!. I am trying to trace a fault, iid tool BT sometimes comes up with Steering ECU internal error fault. I had a reading last night of centre 0 deg , right -457deg and left 1456 deg! and then it froze and would not show any reading other than that when the wheel was turned.
19th May 2017 2:29am |
Sorry to hijack this thread slightly, but I updated my IID Tool to the latest firmware, thinking I needed that to get the SASM Steering Angle ECU info...but still can't get anything.
19th May 2017 2:40pm |
Message the guys at gap.. my iid tool was missing the gearbox ecu part..,quick download and it was fixed 10/10 for service... |
19th May 2017 3:53pm |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 |
Can I ask what you would need these values for ? Just trying to biuld up my knowledge of FFRR's |
19th May 2017 4:33pm |
I wanted to check them against mine as 1 have a fault, I posted I had a very high reading 1000degs more on one side,so wanted to check against others. |
20th May 2017 7:58am |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 |
In bold, this points to a defective SAS, typical behavior. Discotigger: please try the following: Start the engine, Menu--IIDTool Config--Find ECUs, should make the SAS visible. http://www.gap-diagnostic.com/ |
23rd May 2017 7:21pm |
Hi Pat,
23rd May 2017 8:08pm |
Will require further investigation, PM sent http://www.gap-diagnostic.com/
23rd May 2017 8:14pm |
