Home > Technical (L322) > live values on Steering sensor please
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Could some one be kind enough to give me their live values on the steering angle sensor with their iidtool? A degree reading on full lock right and full lock left. I would like to compare degree readings with mine . Thanks
Post #438780 18th May 2017 11:02am
Discotigger
Where are the live values for the steering angle sensors on the IID Tool, can't find anything for them, just been out and plugged my IID in to read them, but there's no mention in the live data menus.
Post #438781 18th May 2017 11:15am
alistairh
I'm home at tea time .. if you haven't had an answer by then I will post up mine 👍
Post #438784 18th May 2017 11:51am
lounge_on_wheels
scroll down on the Live Values, then select Live Values > Live Values ECU > SASM - STEERING Angle > Steering Angle degrees
cheers,
Post #438785 18th May 2017 11:54am
Discotigger
Hmm, couldn't find that option on my BT IID Tool, will have another look later and may need to get the IID updated
Post #438806 18th May 2017 2:40pm
nino_nino
this is what I have, center, full right, full left .
Post #438810 18th May 2017 3:27pm
alistairh
And mine. Left then right
Post #438838 18th May 2017 7:42pm
lounge_on_wheels
Thank you all for doing that for me, it's much appreciated!. I am trying to trace a fault, iid tool BT sometimes comes up with Steering ECU internal error fault. I had a reading last night of centre 0 deg , right -457deg and left 1456 deg! and then it froze and would not show any reading other than that when the wheel was turned.
I did a re calibration reset the faults and this morning and I have 0 deg centre, R -609.8 & L 635.5, I know that when I go for a drive later the fault will return again.
Post #438858 19th May 2017 2:29am
Discotigger
Sorry to hijack this thread slightly, but I updated my IID Tool to the latest firmware, thinking I needed that to get the SASM Steering Angle ECU info...but still can't get anything.
Just checked the ECU files with the IID and it says the SASM ECU is 'not fitted' to my FF. Is this the case, or am I missing something? I have the 2005 Touchscreen model and have the Off-road display on the sat nav that shows the wheel position on the display for when you're off-roading.
Mind you, having looked at the ECU screen on IID, I appear to be 'missing' a few ECUs, as in it says they're 'not fitted'. Shocked
Post #438890 19th May 2017 2:40pm
alistairh
Message the guys at gap.. my iid tool was missing the gearbox ecu part..,quick download and it was fixed 10/10 for service...
Post #438899 19th May 2017 3:53pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Can I ask what you would need these values for ? Just trying to biuld up my knowledge of FFRR's
Post #438900 19th May 2017 4:33pm
lounge_on_wheels
I wanted to check them against mine as 1 have a fault, I posted I had a very high reading 1000degs more on one side,so wanted to check against others.
Post #438969 20th May 2017 7:58am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
lounge_on_wheels wrote:
... I had a reading last night of centre 0 deg , right -457deg and left 1456 deg! and then it froze and would not show any reading other than that when the wheel was turned.
In bold, this points to a defective SAS, typical behavior.
Discotigger: please try the following: Start the engine, Menu--IIDTool Config--Find ECUs, should make the SAS visible. http://www.gap-diagnostic.com/
Post #439361 23rd May 2017 7:21pm
Discotigger
Hi Pat,
Have tried what you suggested, says it finds 24 ECUs but still no joy with the SASM Steering Angle ECU. When I go into the Faults menu and Show all ECUs, it comes up with a list, However where it shows SASM - Steering Angle, directly underneath it says DS2 - Not fitted (In red).
There are a few other ECUs it says are 'Not Fitted', some I can understand as there are for example two versions of Body Processor shown, V10 and v12...the V12 is shown as fitted in my FF.
Any ideas please as to what is going on?
Many thanks. Thumbs Up Bow down Bow down
Post #439367 23rd May 2017 8:08pm
PatGAPInnov
Site Sponsor
Will require further investigation, PM sent Thumbs Up http://www.gap-diagnostic.com/
Post #439368 23rd May 2017 8:14pm
