Home > Maintenance & Mods (L322) > Stripped fill plug( gearbox)
alistairh
After doing mine an good friend has asked me to do the oil/ filter change on his m62 engines fatty. Huge issue being someone's been at it before and managed to completely round the inside of the fill plug. Tried an 8mm Alan head and it's simply turning.. can't fit an Irwin bolt extractor due to the lip of the sump getting in the way..any ideas guys?
Post #437563 8th May 2017 7:16pm
Weegie
Can't tell from the photo but does it stand proud enough to be able to cut a slot across it? John
GAP iiD BT-Sold
Post #437564 8th May 2017 7:18pm
alistairh
I reckon it would maybe be viable. I've tried using a small chisel and it's simply chipping and crumbling.. what would you use to do the cut?
Post #437566 8th May 2017 7:27pm
Weegie
Hacksaw? John
GAP iiD BT-Sold
Post #437569 8th May 2017 7:37pm
alistairh
Already tried lol.. no room in the slightest. Wondering if there's a dremmel that can cut a groove in it?
Post #437572 8th May 2017 7:45pm
Can you just go at it with a cold chisel on the edge to get it turning? .
Post #437573 8th May 2017 7:46pm
alistairh
That's worth a bash. It's taken longer to try and get this off the car than the actuall oil change/ filter change is going to take Laughing
Post #437574 8th May 2017 7:49pm
alistairh
A better pic.. as you can see the plugs tight to the casings edge.. will try your method tomorrow joe..
Post #437579 8th May 2017 8:13pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
You can get a miniature cutting disc for Dremmel, discs don't last long though so get a few. How about an air saw, got one here but where are you?
Edit to say just noticed you're in Scotland, bit of a drive to borrow a saw Laughing
Post #437580 8th May 2017 8:14pm
Weegie
Before starting with the chisel I would be inclined to file a groove in it (if there is room) to lessen the chance of the crumbling you mentioned earlier. John
GAP iiD BT-Sold
Post #437581 8th May 2017 8:15pm
alistairh
Laughing thanks anyway buddy haha
Post #437582 8th May 2017 8:16pm
alistairh
@ weegie. I'm determined now as I hate getting beaten lol..that makes sense
Post #437584 8th May 2017 8:17pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Could you put an Allen key socket in there and weld it round , then unscrew and throw away ? onto no6 Range Rover
Everyone needs a hobby
Post #437613 8th May 2017 11:16pm
nino_nino
hamer in slightly oversized torx key?
Post #437620 9th May 2017 6:10am
RRPhil
I don’t know if it helps at all but this is a view of the plug from above. You can see that there is a fair amount of the head depth that sticks out (although it may be slightly exaggerated in the photo because this plug may not be fully tightened). The piece of the casting that juts out below the plug is there just to provide a ledge or spout for the fluid to pour/drip off when setting the level.
Phil
Post #437631 9th May 2017 9:31am
