![]() | Home > Maintenance & Mods (L322) > Stripped fill plug( gearbox) |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
Can't tell from the photo but does it stand proud enough to be able to cut a slot across it? John
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I reckon it would maybe be viable. I've tried using a small chisel and it's simply chipping and crumbling.. what would you use to do the cut? |
Hacksaw? John
Already tried lol.. no room in the slightest. Wondering if there's a dremmel that can cut a groove in it? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Can you just go at it with a cold chisel on the edge to get it turning? .
That's worth a bash. It's taken longer to try and get this off the car than the actuall oil change/ filter change is going to take |
A better pic.. as you can see the plugs tight to the casings edge.. will try your method tomorrow joe..
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
You can get a miniature cutting disc for Dremmel, discs don't last long though so get a few. How about an air saw, got one here but where are you? Edit to say just noticed you're in Scotland, bit of a drive to borrow a saw ![]() |
Before starting with the chisel I would be inclined to file a groove in it (if there is room) to lessen the chance of the crumbling you mentioned earlier. John
@ weegie. I'm determined now as I hate getting beaten lol..that makes sense |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
Could you put an Allen key socket in there and weld it round , then unscrew and throw away ? onto no6 Range Rover
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
hamer in slightly oversized torx key? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
I don’t know if it helps at all but this is a view of the plug from above. You can see that there is a fair amount of the head depth that sticks out (although it may be slightly exaggerated in the photo because this plug may not be fully tightened). The piece of the casting that juts out below the plug is there just to provide a ledge or spout for the fluid to pour/drip off when setting the level.
