![]() | Home > General (L405) > Hard over bumps |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
Welcome |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
Which wheel size do you have? and have you checked the tyre pressures? |
Hardkor Member Since: 29 Jan 2017 Location: London Posts: 4 ![]() ![]() |
Appreciate the replies .
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Mine is a reasonably hard ride on the same wheels. I would change them to either 21" or 20" you will find it a much softer ride. I think you will get the knocking sorted out under warranty.
I'm afraid I haven't got warranty but was wondering if it can be done under a recall issue. |
22's are less forgiving than the 20's and 21's. My personal preference is the 21's which give a great compromise. Not quite as smooth as 20's but look better IMHO. I'd definitely check the pressures as these can be set for a heavy load and then not set back for normal and it really does make a difference.
If theres been a recall then yes you should have it done FOC.
Thanks again for your prompt replies.
Caddyshack Member Since: 03 May 2017 Location: Guildford Posts: 61 ![]() ![]() ![]() |
Hi All, I have just joined after a few days lurking. Just bought a FF Autobiography from Harwood Pulborough. I mentioned the knocking on front suspension on test drive but was told it was just 22 inch alloys which I planned to change but they wouldn't swap for 20's or 21s off another forecourt car.
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 408 ![]() ![]() |
I've done 40k + miles on 22" wheels, no significant knocking whatsoever and if they try telling you otherwise dig your heels in. Sounds like salesman talk to me and a car of this quality and price should not have any unusual sounds.
Thanks for the support |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
I've got 22's on mine 2016 and it's drives very smoothly with no knocking, hope you get it sorted |
It is good to hear about the 22's being ok as I like the look but hated the ride. Although I thing a Rangie needs a bit more rubber to handle bumps and kerbs. |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
I have a l405 on 22" and the ride is firm but totally acceptable with no knocking whatsoever. the only time this changed was after its first service when it came out of the workshop with 2 psi extra in the tyres and that made the ride appreciably harder.
