![]() | Home > Technical (L322) > Just bought a car all was fine for the first 40 miles... |
Keith A Member Since: 25 Oct 2012 Location: Sherborne, Dorset Posts: 105 ![]() ![]() ![]() |
So I just bought a 58 reg TDV8 this afternoon. Test drive went fine. Everything worked (aside from the rear camera, which he had already told me about).
Thank you.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
hope that is a massive 'phew' once you fit the sensor!
Sure it will be. However, it reset last night and had no troubles at all on a 100mile journey I just did.
L_Ashman Member Since: 10 Feb 2017 Location: Hampshire Posts: 30 ![]() ![]() ![]() |
Doesn't sound too serious Keith, hopefully the sensor should resolve the issue and won't sour the start of your RR experience! |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3256 ![]() ![]() ![]() |
The "U" faults are communication errors and can be ignored if there are no other faults. From the manual:
Fault came back, so changed the right rear abs cable and the fault still persists |
Also on both rear wheels there is a connector not connected to anything. What's it for?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2647 ![]() ![]() |
Just guessing that the connectors may be for TPMS receivers.
Hi Graeme,
D2s get ABS faults when grease escaped from a failing bearing fills the gaps in the sensor ring, but the sensors usually have grease on them too.
Had it on a proper diagnosis machine today. It's getting no reading at all from the right rear wheel. The new sensor might be a dud, so need to transpose one. More than likely a fault wire/connector from the car end though I'd think now. Could be fun finding where the issue is exactly.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Make sure you have fitted the correct replacement sensor , there are a few with different resistances so the abs module doesn't recognise the 'wrong' one and throws out that error. Ask me how I know |
Did you end up buying the £100 land rover one or can you recommend a source?
