Home > Technical (L322) > Just bought a car all was fine for the first 40 miles...
Keith A
United Kingdom 2009 Range Rover Vogue SE TDV8 Buckingham Blue
So I just bought a 58 reg TDV8 this afternoon. Test drive went fine. Everything worked (aside from the rear camera, which he had already told me about).
Fast forward to driving it home and 40 miles later I have the following Big Cry :
HDC Fault
Parking Brake Fault
Terrain Response Fault
Fault Codes:
U0248 - lost comms with remote driver utility module
U0416 - invalid data from vehicle dynamics module
U0401 - invalid data from engine control module
U0402 - invalid data from transmission control module
U0403 - invalid data from transmission case module
U0421 - invalid data from ride level control module
U0122 - invalid data from vehicle dynamics control module
P0500 - vehicle speed sensor A
C1A93 - Right rear wheel speed sensor
So... I'm thinking it can't all be that bad and either a cable has come off or a sensor/switch/relay somewhere has failed.
I'm pretty sure you wouldn't be able to have hidden all of this, particularly as I used a fault code reader before and after the test drive and there was nothing untoward.
Any help greatly appreciated. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Mini Cooper Race Car Smile
Post #436657 1st May 2017 8:14pm
GraemeS
All the faults except the wheel speed sensor fault will have been triggered by the wheel speed sensor fault due to the reliance on accurate wheel speeds by all the various modules.
Post #436661 1st May 2017 8:48pm
Keith A
Thank you.
So U faults are caused by P and C faults Smile
I'll bear that in mind.
£20 for a bosch rear speed sensor.... picking up tomorrow. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #436662 1st May 2017 9:03pm
GGDR
hope that is a massive 'phew' once you fit the sensor!
. Cheers, Greg
Post #436684 2nd May 2017 7:33am
Keith A
Sure it will be. However, it reset last night and had no troubles at all on a 100mile journey I just did.
Picked up a new sensor though and will change it out to be sure. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #436688 2nd May 2017 8:01am
L_Ashman
United Kingdom 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Doesn't sound too serious Keith, hopefully the sensor should resolve the issue and won't sour the start of your RR experience! Thumbs Up
Post #436704 2nd May 2017 9:37am
Weegie
The "U" faults are communication errors and can be ignored if there are no other faults. From the manual:
"If faults with a “lost communication with ...” definition are still present and that there are no other
symptoms observed, they can be ignored. These faults are recorded from time to time for no apparent
reason. If faults with the U prefix and unrelated to a communication error are, simply correct the issues
and use the clear fault function"
So it appears that the only fault to be concerned with is the sensor ones, which you have in hand. You could retain the sensor until (if) they reappear. John
GAP iiD BT
Post #436713 2nd May 2017 11:39am
Keith A
Fault came back, so changed the right rear abs cable and the fault still persists Crying or Very sad
I need to try and check the wiring before the cable, but any other ideas?
On the plus side I fixed the rear camera. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437281 6th May 2017 6:18pm
Keith A
Also on both rear wheels there is a connector not connected to anything. What's it for?
 Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437288 6th May 2017 7:03pm
GraemeS
Just guessing that the connectors may be for TPMS receivers.
Can you get light into the sensor hole to check for contamination/rubbish?
Post #437302 6th May 2017 8:58pm
Keith A
Hi Graeme,
I had a good look down the sensor hole when I changed it. All looked good and clean. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437322 7th May 2017 11:13am
GraemeS
D2s get ABS faults when grease escaped from a failing bearing fills the gaps in the sensor ring, but the sensors usually have grease on them too.
Perhaps chaffed wiring somewhere but an oscilloscope may be required to check for the signal at various points unless you can see a worn or broken spot. A broken wire at the 1st connector perhaps?
Do you get the same DTC when the sensor is disconnected?
Post #437391 7th May 2017 7:08pm
Keith A
Had it on a proper diagnosis machine today. It's getting no reading at all from the right rear wheel. The new sensor might be a dud, so need to transpose one. More than likely a fault wire/connector from the car end though I'd think now. Could be fun finding where the issue is exactly.
Booked in with County Rovers in Chard this Friday for them to have a look at. I'll get the lube out. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437695 9th May 2017 4:42pm
dingg1
Make sure you have fitted the correct replacement sensor , there are a few with different resistances so the abs module doesn't recognise the 'wrong' one and throws out that error. Ask me how I know Embarassed
Post #437711 9th May 2017 5:55pm
Keith A
Did you end up buying the £100 land rover one or can you recommend a source?
Got one from ECP and it was completely the wrong connector at both ends.
Then got a pattern one from eBay (done this before for other cars without issue) but it hasn't cured the issue. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437712 9th May 2017 6:02pm
