![]() | Home > Maintenance & Mods (L322) > Braek Fluid Change and amount needed |
philmc79 Member Since: 10 Sep 2013 Location: Hyde Cheshire Posts: 94 ![]() ![]() ![]() |
Has anyone got any Idea What type of break fluid i should use when changing the fluid in my SC and the amount i should buy, is DOT 4 ok or should i use DOT 5.1, I do a lot of towing and have had quite a lot of break fade the last time out, have upgraded the front and rear pads Brembo so no problems there, any help would be appreciated.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
WM says this,
thanks for that you know how much i need |
i've not looked but that info might be in the WM, .. ... - .- -.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Didn't use more than 2 litres when I changed all my brake pipes, and bled it twice.
