Home > Maintenance & Mods (L322) > Braek Fluid Change and amount needed
philmc79
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Has anyone got any Idea What type of break fluid i should use when changing the fluid in my SC and the amount i should buy, is DOT 4 ok or should i use DOT 5.1, I do a lot of towing and have had quite a lot of break fade the last time out, have upgraded the front and rear pads Brembo so no problems there, any help would be appreciated.
SC 4.2 on an 08 plate running on LPG for the last 60K
Post #435967 26th Apr 2017 12:55pm
WM says this,
WM download link in the wiki... ... - .- -.
Post #435969 26th Apr 2017 12:59pm
philmc79
thanks for that you know how much i need
Post #435970 26th Apr 2017 1:02pm
i've not looked but that info might be in the WM, .. ... - .- -.
Post #435976 26th Apr 2017 1:26pm
Didn't use more than 2 litres when I changed all my brake pipes, and bled it twice.
Just make certain you do not empty either the master cylinder or ABS modulator when you do the job. .
Post #436011 26th Apr 2017 5:51pm
