Home > Technical (L322) > EGR temperature sensor
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
I have had my car plugged in and been told the EGR temperature sensor is sending rogue signals and needs replacing.
I have been told it is 5 hours labour as buried in the engine 2012MY 4.4 TDV8
The car drives fine - what does this temp sensor do ? 2011 Range Rover Vogue SE
Post #435238 17th Apr 2017 8:25pm
Busa1400
You know when you think I have just typed something stupid - a temp sensor obviously measure temperature !
What I meant was what does this do in the grand scheme of things and the health of the car. 2011 Range Rover Vogue SE
Post #435239 17th Apr 2017 8:37pm
GraemeS
Australia
I replaced mine in far less than 5 hours only to have the new one throw the same fault within a few weeks. From other reports it appears that the fault can be ignored. I didn't notice any difference when the new sensor was new.
Post #435250 17th Apr 2017 9:32pm
Macca314
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
Hi. I have got this issue at the moment, seems it connected to fault code P245A and P040A
The first code points to the exhaust
The second points to s sensor in the coolant pipe below the expansion tank. This on tells the EGR valve to open to allow cooling.
The dealership changed one, but it's still got the same fault, has I type it's getting the other this morning..
Hope this helps LandRover 90 1985 300 Tdi Auto, Epsom green
LandRover D1 Premium 1998 300 Tdi Auto Rioja red
LandRover F1 2004 Td4 HSE Auto Giverney green
LandRover FFRR Vogue 20114.4L Tdv8 Fuji white
Post #441297 12th Jun 2017 9:03am
mikeyyn
Hi, I had a fault with EGR sensor, fault code P0486-17 (27) Exhaust gas recirculation sensor B circuit - General electrical failure - circuit voltage above threshold
Turned out to be a faulty throttle body. A lot quicker to replace than the EGR and sensor.
Go figure.......
Post #442302 22nd Jun 2017 3:23pm
TOF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
What lead you from that error code to a throttle body replacement...? Mine has the same code also..
Post #442449 23rd Jun 2017 5:27pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
What is the fault code you have exactly?
The code that CAN be safely ignored is P040(D) because that is the passenger side manifold temperature sensor. The sensor is calibrated to read a certain range and if the range is exceeded, it throws up that fault and from my research, all or most 4.4 TDV8s will have this and have it recurring.......
I wouldn't ignore the P040(A) or any other letter other than 'D" until you have concrete info. It may not be the sensor but something else and as it's EGR related.........
Post #442455 23rd Jun 2017 6:18pm
TOF
Mine is P040(D)
So that is safe to just ignore and carry on than...
Post #442462 23rd Jun 2017 6:58pm
Giantlandyman
Yes. Had it verified by Land Rover CS, Land Rover Technical, a dealer workshop manager and an indy.
Post #442466 23rd Jun 2017 7:35pm
mikeyyn
TOF:
The dealer had it in and diagnosed the throttle body after an indi couldn't work it out.
Seems to be fixed now though.
Post #442671 25th Jun 2017 5:35pm
dhallworth
That sensor not working will stop the DPF regenerating on the car.
Ours has just had that sensor changed at 13k miles. The dealership managed to snap it in the manifold so had to remove the engine to get the manifold off. They sent the manifold to a machine shop to get the sensor removed and they couldn't get it out so they ended up fitting a new manifold.
Apparently they didn't charge us the full amount of labour that it should have been but the labour alone was over £800. The manifold was over £300, the total bill was in the region of £2k.
I'm just about to have a chat with LR Customer Services as there's no way a 13k mile car that has never done short journeys in it's life should need that sort of work carrying out.
Post #442718 26th Jun 2017 10:01am
