![]() | Home > Technical (L322) > EGR temperature sensor |
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
You know when you think I have just typed something stupid - a temp sensor obviously measure temperature !
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2654 ![]() ![]() |
I replaced mine in far less than 5 hours only to have the new one throw the same fault within a few weeks. From other reports it appears that the fault can be ignored. I didn't notice any difference when the new sensor was new. |
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 ![]() ![]() ![]() |
Hi. I have got this issue at the moment, seems it connected to fault code P245A and P040A
mikeyyn Member Since: 17 Oct 2011 Location: Notts Posts: 53 ![]() ![]() |
Hi, I had a fault with EGR sensor, fault code P0486-17 (27) Exhaust gas recirculation sensor B circuit - General electrical failure - circuit voltage above threshold
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 ![]() ![]() ![]() |
What lead you from that error code to a throttle body replacement...? Mine has the same code also.. |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
What is the fault code you have exactly?
Mine is P040(D)
TOF:
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3203 ![]() ![]() ![]() |
That sensor not working will stop the DPF regenerating on the car.
