![]() | Home > In Car Electronics (L322) > Dab Radio |
l322novice Member Since: 15 Jan 2016 Location: South Posts: 32 ![]() ![]() ![]() |
When did DAB Radio become available in the L322? 5.0 Supercharged methinks. Also is there a kit to convert our radio to Dab and have it looking bog standard? |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
not sure on the age of your car, there are many FM transitters out there, you could maybe get a DAB portable radio with FM trasmitter all hidden in the glovebox tune your FM radio into your DAB bluetooth/sat nav will still work as normal
Thanks Lukie, looks good |
FD Member Since: 15 Jan 2017 Location: Bristol Posts: 31 ![]() |
Anyone used one of those and can report on how reliable they are?
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 ![]() ![]() ![]() |
^ do you mean the Alpine unit? Yes, I have it and find it perfectly acceptable |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Alanm do you have it plugged in direct to the cigar lighter or hard wired? I was trying to find one I could discreetly hide away and maybe keep it wired in the glovebox.. I have an intravee but the dab units for it are like hens teeth to source.. |
Thanks Alanm |
I have it hard wired and plugged into the aux input of the RSE. The only thing you can see is the display unit
Great. Just what I require. Thanks |
Is it possible to fit DAB Module AH42-19C032-AE AH42-14D401-AA to an earlier (2005 touch screen) radio? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
the fibre optic comms are different so no its not possible... ... - .- -.
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 ![]() ![]() ![]() |
Stan
hybrid tv tuners are ok but i've not heard dab being retro fitted Matt... ... - .- -.
Thanks Stan |
