Home > In Car Electronics (L322) > Dab Radio
l322novice
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Dab Radio
When did DAB Radio become available in the L322? 5.0 Supercharged methinks. Also is there a kit to convert our radio to Dab and have it looking bog standard?
Post #435084 16th Apr 2017 3:44pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
not sure on the age of your car, there are many FM transitters out there, you could maybe get a DAB portable radio with FM trasmitter all hidden in the glovebox tune your FM radio into your DAB bluetooth/sat nav will still work as normal
found one for £40 on ebay
www.ebay.co.uk/itm/252859825149
Post #435190 17th Apr 2017 12:32pm
l322novice
Thanks Lukie, looks good
Post #435203 17th Apr 2017 2:42pm
Alpine Ezidab. Do a search and you'll see Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #435208 17th Apr 2017 3:57pm
FD
Anyone used one of those and can report on how reliable they are?
DAB signal in my old car was excellent 100% of the time due to an aerial on the inside of the screen. Guessing this won't be a match for that though?
Post #435224 17th Apr 2017 6:03pm
^ do you mean the Alpine unit? Yes, I have it and find it perfectly acceptable Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #435236 17th Apr 2017 7:18pm
alistairh
Alanm do you have it plugged in direct to the cigar lighter or hard wired? I was trying to find one I could discreetly hide away and maybe keep it wired in the glovebox.. I have an intravee but the dab units for it are like hens teeth to source..
Post #435248 17th Apr 2017 8:04pm
FD
Thanks Alanm
Post #435251 17th Apr 2017 8:47pm
I have it hard wired and plugged into the aux input of the RSE. The only thing you can see is the display unit
http://www.fullfatrr.com/forum/topic17064.html?highlight=ezidab Got - 2017 SDV8 Autobiography in Loire Blue
Post #435252 17th Apr 2017 8:53pm
alistairh
Great. Just what I require. Thanks Thumbs Up
Post #435253 17th Apr 2017 9:11pm
l322novice
DAB Radio
Is it possible to fit DAB Module AH42-19C032-AE AH42-14D401-AA to an earlier (2005 touch screen) radio?
Post #461156 17th Dec 2017 3:36pm
the fibre optic comms are different so no its not possible... ... - .- -.
Post #461159 17th Dec 2017 4:15pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Stan
Is that also the case for a 2006 model - I ask as I have successfully fitted a AH42-19C032-AE hybrid tv controller , and can get the DAB controller from the same vehicle if it will work - part number as above
Matt
Post #461311 18th Dec 2017 7:27pm
hybrid tv tuners are ok but i've not heard dab being retro fitted Matt... ... - .- -.
Post #461319 18th Dec 2017 8:01pm
m@ttsFF
Thanks Stan
Post #461329 18th Dec 2017 8:29pm
