![]() | Home > Technical (L322) > 4.4tdv8 plastic intake manifold |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
anyone know of any splitting like the tdv6s one are prone too? Cheers
found one: http://www.fullfatrr.com/forum/post424043.html#424043 Cheers
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
does your engine not have a timing chain? Current: TDV8 (3.6) RRS HSE
Ritchey Member Since: 16 Apr 2017 Location: Chester Posts: 7 ![]() ![]() ![]() |
Sorry yes timing chain, think they're recommended for change at around 105,000 miles. I'm on 83k at the minute and would likely hit 100k in the next 12 months. |
Forget it! A chain should never really go wrong, maybe the tensioner eventually. Current: TDV8 (3.6) RRS HSE
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
I suspect the belt change interval is for the accessory belts. |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Mine split last year whilst on holiday in France. Had to get a replacement fitted at the LR dealer in Nantes |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8689 ![]() ![]() ![]() |
No cam belt, only belts are the 2 aux belts at the front. As said at some point the chain tensioner might need changing but I doubt that would be anything like 100k more like 200k.
Thank you for all the replies and information, very much appreciated. |
Update is that it is one of the 4 rubber boots that has split, unfortunately not covered by my warranty but about £100 for the 4 boots and £150 in labour. So it could've been worse.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Thanks Baltic, that's a huge help.
