Home > Technical (L322) > Whirring noise
frikkadel
South Africa
Whirring noise
I have a TD6 '03. has 223,000kms on.
The other night came home and heard a slight whirring noice as if a serpentine belt is rubbing against something.
I couldnt see anything and the belt seems to be in place.
Was too scared to drive after that for a week or so.
Today, i got the courage that if i got stuck i would have a friend to help tow me. So off i went, didnt hear any whirring, except that the whine form the fuel pump seems louder than normal. I presume its the fuel pump.
no noise until about 5 kms from home at the same place i heard the noise before.
Stumped.
Can the fuel pump do this before knackering itself?
Is it the gearbox or torque convertor( the box is pulling strong like a train)?
Still stumped, the slight whirring noise doesnt appear until i have done about 20kms and the engine is nice and hot.
what i dont want to do is drive it until something breaks to find out the problem, which is not really the worry, the worry is breaking down in africa , even if its the city , at night.
Post #434168 7th Apr 2017 1:42pm
Do you only hear it when stationary? if so it could well be your air con compressor , they whir when they get low on gas. 2008 MY Supercharged
Post #434257 8th Apr 2017 11:11am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I had this the other day, when I parked up I was convinced I could hear the steering column motor whirring away all by itself.
So in a panic and not wanting to burn the steering column motor out I rushed to disconnect the battery, when I lifted the bonnet I realised the whirring was coming from the ECU cooling fan, so panic over Whistle
It's odd that it sounds as if it's coming from the drivers footwell though....... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #434269 8th Apr 2017 1:24pm
frikkadel
South Africa
Axle
i must say thank you for your comment, i took the fat one for a drive yesterday and drove no aircon and no whirring.
So this morning i will take the car to an aircon guy just down the road and get the gas sorted.
This makes sense to me as a few months ago in the middle of summer, i took a long drive and it was 38c, and then felt a slight shuddering come from the floor. i switched the aircon off and it was gone. I made the assumption it was getting very hot and the clutch was coming on and off.
So , i will get this sorted and get back to you later.
Post #434419 10th Apr 2017 6:31am
frikkadel
South Africa
was the aircon
Ok, i popped down to the aircon repair shop, within 1 minute the black technician was onto the job. Told me within 2 mins my system was almost empty.
He Purged and the refilled with oil and gas, and off i was. all within 20 mins.
he was telling me that the biggest problem is that people run the aircons till they are dry and then the bearings and pistons get stuffed in the compressor.
He told me that the compressor form JLR is 17k in rands and if your unit is removed and rebuilt to work like new its only 6k.
Nice and quiet. I have to go to bloemfontein in the course of the next couple of weeks and thats about 1000kms both ways , so i reckon if the aircon is fine for that distance, the problem will be sorted.
Post #434455 10th Apr 2017 12:27pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
But why did the gas Leak out?
Post #434469 10th Apr 2017 2:57pm
frikkadel
South Africa
well the guy was saying that after many years of not being serviced the oil breaks down and the gas also stops working and then thats where the problem starts. he says you definitely need to service the aircon once every two years.
there was oil and gas in and when they purged it it was dirty and as he says not effective.
cant tell you more than that.
Post #434474 10th Apr 2017 3:54pm
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
Great result indeed.
I am led to believe that one should switch ait con on about knce every month or so.
This keeps the system 'moving' and the joints 'moist'
Lubricating everuthing and stopping joints from drying oot.
BOFA Made in Scotland frae 'Girders'
Post #434555 11th Apr 2017 7:06am
