Home > Technical (L322) > L322 4.2 SC Fuel Gauge Reading too High
Vergil300
Hi all,
L322 2006 4.2 SC.
I have an issue that has been quite embarrassing...
Basically my fuel gauge reads about 1/10 maybe 1/9 full and the computer shows 60-80 miles left when the tank is empty, learned the hard way... twice.
Problem with the sender? or just need re-calibrated, if so how do I do that? I heard something about leaving the key in the ignition when you disconnect the battery can Censored it up, can this be used to reset it also?
Thanks.
G
Post #433811 4th Apr 2017 12:52pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Mine has run out of fuel once when this has happened and said that I had 20 odd miles left in the tank. Only happened once though. Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #433815 4th Apr 2017 1:33pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I know the TDV8's have 2 fuel senders and the connection between them can corrode/get fuel in the connector and give a false reading. Not sure if SC is the same, but could be your problem 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #433841 4th Apr 2017 5:42pm
GGDR
http://www.fullfatrr.com/forum/topic41061.html Cheers, Greg
Post #433852 4th Apr 2017 7:05pm
