![]() | Home > Technical (L322) > L322 4.2 SC Fuel Gauge Reading too High |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Mine has run out of fuel once when this has happened and said that I had 20 odd miles left in the tank. Only happened once though. Alex
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I know the TDV8's have 2 fuel senders and the connection between them can corrode/get fuel in the connector and give a false reading. Not sure if SC is the same, but could be your problem 56 TDV8 Vogue SE
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/topic41061.html Cheers, Greg
