Home > Dealership & Service Feedback > Gearbox fluid change Northamptonshire/Leicestershire area?
Webbie
Can anyone recommend a specialist to do a transmission fluind change on my 4.4 TDV8. I'm looking for a garage located somwhere in or around the Northamptonshire/Leicestershire boarder area?
Just coming up to 69,000 miles, is there any other work that should be done to the box at the same time? The rest of the car is all serviced up to date, it even passed its MOT yesterday with no advisories.
Post #432571 25th Mar 2017 11:15am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
i use http://iawaclassicsand4x4.co.uk/index.html recommended by Harris.
Post #432583 25th Mar 2017 2:36pm
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
I have used a garage in Coventry called BDK its on the foleshill road they did my full fat very good customer service and very knowledgeable
Post #432648 25th Mar 2017 10:24pm
Webbie
Thanks, I will give them both a call.
Post #432751 26th Mar 2017 6:16pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Not too difficult to do yourself - plenty of info on here as to how. As an aside, whether you do it yourself, or have it done, replace the sealing sleeve where the wiring loom goes in to the gearbox - less than �10 to buy, but you have to replace it with the gearbox sump pan removed (as this is the only way to get at the retaining clip).
Wasn't aware of the fact this sleeve fails when I drained and re-filled my gearbox about 18 months ago, end result now have to dump �175 worth of transmission fluid to change a �10 seal !! Big Cry Big Cry 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #433204 30th Mar 2017 2:05pm
Webbie
Thanks Ray, I thought my box on the 4.4 TDV8 was sealed for life and required a specialist company to pump the new in and the old out. My Independent garage didn't want to do it, I will investigate a little further.
Post #433261 30th Mar 2017 7:14pm
Not heard that before.... There is nothing that can't be fixed with a hammer😜😜
Post #433279 30th Mar 2017 9:29pm
