Home > Technical (L322) > Programing remote for auxilary heating
Wolverine
Auxilary (webasto) heating
I had battery changed on my TDV8 Vogue and since then cant get the remote to fire up the auxilary heating. Can program it in setup on screen in the car, but thats it. Can anyone help with reprograming the remote please?
Thanks
Post #430646 9th Mar 2017 10:37pm
Use the search function.
You have to repair the remote, can't remember the exact sequence but it involves pulling a fuse to put the receiver in learn mode. Thumbs Up
It may be easier to find the receiver in the back cubby of the car and pull the power on that.
Instructions are here https://www.webasto.com/fileadmin/webasto_...rt-t91.pdf There is nothing that can't be fixed with a hammer😜😜
Post #430659 10th Mar 2017 7:50am
Wolverine
Thank you for your help, will give it a try and see how I get on.
Post #430684 10th Mar 2017 1:07pm
Mr Tee
Did this the other week. Take the right hand boot panel off, you will see the unit mentioned without unbolting anything, pull the plug, wait, bang it back in and it should work, remember it won't work if the outside temp is above 6 IIRC. Mines a post 2010my, would help if you filled out your car details Thumbs Up
Post #430708 10th Mar 2017 3:56pm
Wolverine
Thanks for your help. I thought my car details were showing?! TDV8 2008 Vogue SE
Post #430766 11th Mar 2017 12:08am
