Home > Maintenance & Mods (L322) > DPF Full Warning
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
DPF Full Warning
I got the 'DPF Full - read handbook' warning over the weekend.
Did the 20 min run with revs at 2500 - 4000 (3 times!) and it finally cleared.
Actually though it hadn't as I was expecting the warning to go while the car was running. Thankfully it did when I came back to it after the third attempt.
Anyway ...
Is this just something which happens - I don't do many motorway miles, so the car is usually at low revs around town.
Or is there something else I should be looking into?
Post #430193 6th Mar 2017 11:02am
dont use mine much and this happened only once for me since i bought mine in may 2016...
i ran mine at 50mph for around 15 minutes and it cleared...all part of owning a tractor i suppose.. Laughing
btw, can you fill in your car details in your profile please.. ... - .- -.
Post #430196 6th Mar 2017 11:07am
GAC23
Thank you for the reassurance, Stan.
I shan't worry any more Very Happy
And have added details as requested.
G.
Post #430198 6th Mar 2017 11:12am
GGDR
Hi all,
Had DPF full amber warning. Quickly changed to red - 'take to dealer'.
...and now I'm on limp mode. Making best speed I could get to try and clear it was 2500rpm for 2 x 45 min runs. Kept the box in 4th to keep the revs there. Wouldn't get over 60mph.
So the red warning prevents you from performing the clear out run....
Anyone experienced this? Cheers, Greg
Post #431120 13th Mar 2017 9:47pm
to clear the dpf you dont have to have high revs, a steady 15-20 run at around 50mph should clear it.....maybe your high revs didnt help the process .. ... - .- -.
Post #431126 13th Mar 2017 9:59pm
GGDR
hmmm. thanks Stan. Well it was a good run to get the heat in the exhaust up... It's about temperature as I understand it.
Heading back to dealer tomorrow because even if I could get it to improve, I would've thought the engine mgmt system needs to be cleared now...
Any idea what the dealers to the "regenerate" it?
. Cheers, Greg
Post #431128 13th Mar 2017 10:07pm
chief64
Norway 2010 Range Rover Autobiography TDV8 Buckingham Blue
DPF
When I get warning DPF full, it work to drive up hill for some time,but in the winter time,is it not so easy. In winter time,I just buy from Wurth two spray can with DPF cleaner, dismantling nippel for presure sensor before DPF, spray in to DPF,putting back nippel and take a drive, then you see some smoke and after a few km is the light gone.
If going to a workshop, then some have washing system that they conect to DPF.
You can also start the regenerating, with a computer,that is also done by many workshop.
Post #431143 14th Mar 2017 7:58am
GGDR
thanks chief64 - really helpful Cheers, Greg
Post #431234 14th Mar 2017 11:15pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
My understanding is that via the diagnostics, they can force a regeneration without needing to take the car on a run or rely on the car detecting the necessary conditions being present for regeneration to begin.
It is certainly hat way for Fords
Post #431263 15th Mar 2017 10:12am
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Just take it for a good run every fortnight and don't be overly gentle and you should be ok , oh the joys of modern emission controls Confused
Post #431398 16th Mar 2017 10:56am
stu
Can the IID tool instigate the regeneration process? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443243 1st Jul 2017 7:01pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Yes it can be done but as the car is stationary, the garage uses a fan to keep the air flowing into the Rad. be easier to go for a wee drive tbh Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #443244 1st Jul 2017 9:53pm
Never had a problem with mine, too busy keeping that second turbo spinning so I don't have clouds of smoke following me.....so the DPF is always clean!!!! There is nothing that can't be fixed with a hammer😜😜
Post #443254 2nd Jul 2017 7:57am
Baltic Blue
NMJ,
Having the turbo drain mod done has transformed my driving style and love of my 4.4.
I was constantly aggressively driving trying to get the revs up to open up the 2nd turbo to blow out the smoke cloud.
I now drive relaxed and simply enjoy the power on tap when I need it.
I don't know which is best for the DPF but I do know that I don't regret for 1 minute the pleasure of driving I now enjoy.
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443257 2nd Jul 2017 8:46am
Only had the cloud once, so I'm not sure that I could convince LR to do the mod, even though they had that turbo drain off last year I'm not convinced they would have done the mod when they reassembled it. So at the moment I'm unsure if it's been done or not...... There is nothing that can't be fixed with a hammer😜😜
Post #443260 2nd Jul 2017 9:00am
