![]() | Home > Maintenance & Mods (L322) > TD6 vortex crankcase filter |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
Hi all,
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Filter only... 2010 3.6tdv8 180k km.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
I would suggest filter only as well, unless you know there is a problem with your housing.
nar53 Member Since: 04 Nov 2015 Location: Le Mans Posts: 120 ![]() ![]() ![]() |
Should this be replaced as a service item? My fatty is coming up for its 1st service in my ownership & wondered if I should be changing this at the same time?
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
I would look at it as a service item. The advantage with the vortex filter is that it is a one off replacement thus avoiding the need to access it at each service which is bit of a pain in the rear end. John
OK Weegie, Thanks for that I'll do it |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
Unnecessary quote removed
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
I bought from that seller you linked and it wasn't an pleasant experience. |
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 ![]() ![]() ![]() |
Filter only mate, I did both my Td6 and my daughter Td4 in her Freelander. I cleaned the housing out with brake cleaner popped it back together. Never had a problem. I also fitted K&N air filters into both vehicles then you don't need to go in there again for awhile. Change the little clear bulb style filter on the turbo at the same time. |
