Home > Maintenance & Mods (L322) > TD6 vortex crankcase filter
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Hi all,
Need to change my crankcase filter so obviously going to upgrade to the vortex type.
Question is, is it preferable to get the complete unit ie. housing and filter or no point, and just shove the new filter in the existing housing?
Found them both listed on fleabay:
Filter and housing
Filter only
Cheers 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #429733 2nd Mar 2017 2:29pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Filter only... 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #429734 2nd Mar 2017 3:04pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I would suggest filter only as well, unless you know there is a problem with your housing.
I'm not 100% but i'm sure i've heard that the valve on them can get blocked, so might just be worth checking its all clean before reassembling.
I changed just my filter last time, and it's been fine since but as I'm going to do an oil change soon, I decided to buy the vortex type so I can fit and forget about it!
Post #429741 2nd Mar 2017 4:32pm
nar53
France 2002 Range Rover Vogue Td6 Giverny Green
Should this be replaced as a service item? My fatty is coming up for its 1st service in my ownership & wondered if I should be changing this at the same time?
Cheers....
Post #429792 2nd Mar 2017 9:18pm
Weegie
I would look at it as a service item. The advantage with the vortex filter is that it is a one off replacement thus avoiding the need to access it at each service which is bit of a pain in the rear end. John
GAP iiD BT
Post #429793 2nd Mar 2017 9:22pm
nar53
OK Weegie, Thanks for that I'll do it Thumbs Up
Post #429794 2nd Mar 2017 9:34pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Re: TD6 vortex crankcase filter
Unnecessary quote removed
i bought one of those filters and it wouldn't go in the casing, it turned out the small notch was in the wrong place, so i had to file a new one. i contacted the supplier and they said that it was very unusual and that i probably had a pattern filter housing. possible but unlikely, as it still had the loo roll type filter, so why would anyone change the housing?
Post #429804 3rd Mar 2017 12:01am
SidewaysMatt
Cheers all. I'll just order the filter and see how it goes.
Interesting about the notch though - I'll see if I have the same problem. 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #429844 3rd Mar 2017 11:20am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I bought from that seller you linked and it wasn't an pleasant experience. Censored
Yes just buy the filter without housing.
Post #429952 4th Mar 2017 1:23am
Macca314
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
Filter only mate, I did both my Td6 and my daughter Td4 in her Freelander. I cleaned the housing out with brake cleaner popped it back together. Never had a problem. I also fitted K&N air filters into both vehicles then you don't need to go in there again for awhile. Change the little clear bulb style filter on the turbo at the same time.
Post #430116 5th Mar 2017 6:14pm
