![]() | Home > Technical (L322) > gearbox delay when cold? |
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 ![]() ![]() ![]() |
Hello, does it come up with any messages in the message centre on the instrument cluster?
javal322 Member Since: 17 Feb 2017 Location: wales Posts: 41 ![]() ![]() |
hi , i get no warnings or messages , shes done 175k miles but the gearbox was replaced with a recon unit 15k ago by the previous owner , have just done a gearbox oil and filter change along with a full engine service too |
Hi do you know if the torque convertor was changed? was it a exchange unit or a second hand one?
Mine's done that when it's been left a few days and it's cold. Done it for years. Only lasts a few metres though. |
i dont know about the torque converter , i have been wondering if thats suspect as something feels like its slipping under load , not free revving but locked and slipping? like when its changed up too many gear accidently it sits at low revs but feels like something isnt quite right this is my first auto though so it could be perfectly normal , she seems to rev quite high in generall too , way higher than most autos iv been in passenger |
how long does yours take to start moving? this can be anywhere from 0-30 secs ! , just sits there freely revving sometimes going up the gears in manual helps speed the process up |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
A few seconds for mine, however, I have noticed if I let it tick over a little while, she engages a lot quicker.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
May not be the same thing but we had that in ours a while back, but only going into reverse. It turned out it was a crack in the valve block which was causing a pressure loss. Not sure if the entire process but a pm to RRphil would be an idea. |
yeah mine is quite a long time and very random , dosnt seem to do it when hot or having already been driven a mile or so i did wonder about sound deadning under the bonnet with dynamat or similair , its not a very luxury vehicle revving its tits off lol ! |
that sounds similair to my issue but mines in drive , if you put it in manual SOMETIMES seems to engage quicker but still takes a while , do you have a link to his profile? still new on this forum so learning how to use it lol |
Glenn* Member Since: 12 Oct 2016 Location: Kernow Posts: 72 ![]() ![]() |
I had this just recently , bought in july with a rebuilt gear box which had only done a few hundred miles.
Have a look at this thread. Didnt realise yours is a TD6, mine is a 4.4 Petrol V8
It moves straight away, but there's no creep and it requires a bit of throttle. Maybe you have a different issue. |
mine has just had a gearbox service , the changes were much smoother and better after but my other issue seems to have got worse? , not sure what oil it has as it was from ebay? |
