Home > Maintenance & Mods (L322) > 4.2SC 10% pulley
kyle h.
United States 2006 Range Rover Westminster 4.2 SC V8 Java Black
So I noticed that there is a switch? on the end of the throttle pedal. I assume this is a WOT switch, maybe for protecting the transmission? But when I stay out of this switch I get 10psi to hold strong. As soon as I get into this switch I go back to 8psi...which is what the stock pulley was.
Post #428304 18th Feb 2017 10:31pm
stucart
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Quite interested in this mod, anyone had it done at Powerhouse and happy with results, if anyone local to me id be interested in a comparison with my standard spec one???
Post #428483 20th Feb 2017 10:27am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
i had a company somewhere doing the pulley and remap and exhaust for the 5-0 to get to 640bhp somewhere on my mac if i can still find it. _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #428538 20th Feb 2017 6:27pm
stucart
Scottyav, that would be good if you could. Mind you Sheffield isn't too far away for me if have go Powerhouse.
Post #428575 20th Feb 2017 9:46pm
Scottyav
Thats why im looking at 5-0 b for the 600+ bhp Evil or Very Mad but grey black trim under £70k are rare and thats only colour i want Sad _____________________________________________________
Post #428577 20th Feb 2017 9:51pm
Scottyav
Pulleys http://www.powerhouse.uk/
remap 600+
https://viezu.com/
Scottyav wrote:
Custom Land Rover - Range Rover Tuning and ECU remapping and supercharger pulley upgrade package.
Power increases up to 640bhp available Whistle
viezu technologies
Evesham
Worcestershire
WR111GP
Phone: 01869 324402
Email: info@viezu.com
Post #428587 20th Feb 2017 10:24pm
stucart
Cheers Scottyav, will have a browse on their sites. Very Happy
Post #428618 21st Feb 2017 10:29am
stucart
Just emailed Powerhouse, apparently they don't offer a fitting service for the RR Sad
Looks as if it could be a buy the parts :- Modified snout with 10% pulley fitted and do it myself?
Post #428626 21st Feb 2017 11:38am
kyle h.
I haven't read through the repair manual to see if I can piece together how things are working and what that switch is for...but. Today I had a short drive and thought that maybe the DSC may have some interaction with that switch. So I turned it off and I don't seem to see the boost cut/limit at 8psi. Needs more testing but this is interesting Smile
Post #428723 22nd Feb 2017 12:29am
kyle h.
After some light reading:
"A detente mechanism is located at the forward end of the housing and is operated by a ball located on the drum. At near maximum throttle pedal movement, the ball contacts the detente mechanism. A spring in the mechanism is compressed and gives the driver the feeling of depressing a 'kickdown' switch when full pedal travel is achieved."
"The APP sensor has two potentiometer tracks which each receive a 5V input voltage from the ECM. Track 1 provides an output of 0.5V with the pedal at rest and 2.0V at 100% full throttle. Track 2 provides an output of 0.5V with the pedal at rest and 4.5V at 100% full throttle. The signals from the two tracks are used by the ECM to determine fueling for engine operation and also by the ECM and the TCM to initiate a kickdown request for the automatic transmission."
So it sounds like the WOT switch is the detente mechanism that is only there to give feeling to the driver. I understand the need for the pedal to feel as if it were an actual throttle cable...but to add the kick down switch feeling is strange to me. In any case, the kick down operation is obviously monitored and used. And I imagine is has some power limiting qualities as IIRC the 6HP26 trans is maxed out with torque/hp on the 4.2SC engine.
Post #428794 22nd Feb 2017 3:59pm
Carl 40BMI RRSC
England 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
How much they quote you for this bud? I’m contacting them tomorrow for same šŸ‘
Post #520915 7th Jul 2019 6:58am
