Home > Maintenance & Mods (L322) > Engine Cutting Out Intermittently - 2012 4.4 TDV8
Page 2 of 5 <12345>
Baltic Blue
Hope this helps. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #427310 11th Feb 2017 2:59pm
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
stan wrote:
item number one,
Is that definitely the 4.4 TDV8 2012. I can't find it...
Post #427311 11th Feb 2017 3:11pm
Baltic Blue
Best thing we ever did Stan !!! G reg 2.5VM Vogue Portofino red 1991- 1999
Post #427312 11th Feb 2017 3:12pm
Mr. Green ... - .- -.
Post #427317 11th Feb 2017 3:44pm
bwelton
Ok, removed and reseated 3 connectors and refitted.
Have to wait and see if the engine cut out is solved.
Post #427324 11th Feb 2017 5:17pm
GraemeS
The pictures appear to be for a LHD vehicle as my RHD vehicle has the PCM on the left just in front of the battery. Furthermore, the PCM appears to have 2 connectors (one with very many wires) whereas the Transfer Case control module that's mounted on the RHS has 3 connectors.
Post #427335 11th Feb 2017 8:06pm
bwelton
Ok. Problem still there. I managed to capture of log of the engine waivering in Revs and then cutting out.
I'm not sure which Line Values I should be choosing as I'm not sure if I am capturing the right logs.
Any thoughts ?
Post #427339 11th Feb 2017 8:55pm
proser
do you get any variance in the two MAF readings ?? Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #427344 11th Feb 2017 9:31pm
GraemeS
The 2nd MAF's values will be of no consequence at idle.
Post #427352 11th Feb 2017 10:25pm
proser
who said anything about at idle Question
but then depending upon the response there could be a variance at idle as well. Regards
Mark
2012 Westminster
Post #427354 11th Feb 2017 10:29pm
GraemeS
The graph shows engine speed as idle or not much more. The 2nd turbo doesn't get used until around 2500 rpm so I expect that its MAF wouldn't see any airflow.
A low output crankshaft position sensor is a prime candidate for the engine spinning without firing when trying to start and also a good candidate for intermittent engine cessation. The graph showing engine speed momentarily dropping to zero yet obviously the engine hadn't stopped because it then spiked to 1400 rpm is the real clue.
I would start looking at the sensor wiring harness. The sensor is located low in the RHS (not LHS as stated earlier) of the block at the back of the engine where perhaps its wiring has chaffed and is intermittently shorting, or the sensor is loose.
Post #427369 12th Feb 2017 12:31am
bwelton
Hi All,
Just to clarify what was happening with the vehicle. I was drinking up to my house at about 20mph and the engine cut out completely. I rolled to a safe stop.
I then plugged in the IIDTool, to grab the Faults and some Live Values.
I think the failure happened at 11:02:2017 20:01:##
I had earlier changed a configuration file as I had a problem with Door Mirror Puddle Lights. I had enabled these in file and now they are reporting as failures. There is a separate thread on this subject. http://www.fullfatrr.com/forum/topic41314.html
Amyway, after I plugged in the tool and gathered the faults, I restarted the vehicle and drove in to my driveway. On the driveway, the engine started to vary revs as idle, as if it were going to cut out. That is when I captured the Line Values and graphs I.e. As a second failure point.
Do you hav guestions of any other line Values I should look to capture today ?
Thx
Below are the Faults list.
VIN: HIDDEN
L322 - Range Rover 2012
Vehicle scanned on 11-02-2017 20:02
Using IIDTool BT V3.0 B2444
AAM-Audio Amplifier
B1A05-13 (2F) Speaker 5 circuit - General electrical failure - circuit open
( on 11-02-2017 19:44:44 at 67348 km )
- Test Failed
- Test Failed This Monitoring Cycle
- Confirmed
- Test Failed Since Last Clear
B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open
( on 11-02-2017 17:47:08 at 67348 km )
- Test Failed
- Confirmed
B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open
- Test Failed
- Confirmed
ABS-Brake Module
U0401-68 (AB) Invalid data received from engine control module/powertrain control module - Algorithm based failure - event information
( on 11-02-2017 20:01:14 at 67357 km )
- Test Failed
- Confirmed
- MIL Requested
ADCM-Active Damping
U0401-68 (AF) Invalid data received from engine control module/powertrain control module - Algorithm based failure - event information
( on 11-02-2017 20:01:15 at 67357 km )
- Test Failed
- Confirmed
- MIL Requested
BCM-Body Control
B1D17-87 (2F) Bus circuit - Bus signal/message failure - missing a message
( on 11-02-2017 17:03:09 at 67344 km )
- Test Failed
- Confirmed
B10AD-87 (2F) Rain sensor - Bus signal/message failure - missing a message
- Test Failed
- Confirmed
B112C-87 (6C) Interior motion sensor - Bus signal/message failure - missing a message
( on 11-02-2017 17:08:41 at 67348 km )
- Confirmed
- Test Not Completed This Monitoring Cycle
CCM-Cruise Control
U0415-81 (AF) Invalid data received from ABS control module - Bus signal/message failure - invalid serial data received
- Test Failed
- Confirmed
- MIL Requested
U0417-81 (AF) Invalid data received from parking brake control module - Bus signal/message failure - invalid serial data received
( on 11-02-2017 20:02:14 at 67357 km )
- Test Failed
- Confirmed
- MIL Requested
U0418-68 (2E) Invalid data received from the brake system control module - Algorithm based failure - event information
- Confirmed
DDM-Driver Door
B1166-15 (6C) Front right puddle lamp output - General electrical failure - circuit short to battery or open
( on 11-02-2017 17:09:16 at 67348 km )
- Confirmed
IPC-Instrument Pack
U0128-00 (2E) Lost communication with parking brake control module
( on 11-02-2017 19:44:52 at 67348 km )
- Confirmed
PBM-Parking Brake
U0401-00 (2B) Invalid data received from engine control module/powertrain control module
- Test Failed
- Confirmed
PCM-Engine TDV8
P065A-00 (27) Generator system performance
( on 11-02-2017 20:01:35 at 67357 km )
- Test Failed
- Pending
P0105-16 (2A) Manifold absolute pressure/barometric circuit - General electrical failure - circuit voltage below threshold
( on 11-02-2017 20:01:17 at 67357 km )
- Confirmed
P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high
( on 11-02-2017 17:03:14 at 67344 km )
- Test Failed
- Confirmed
P0336-64 (2F) Crankshaft position sensor A circuit range/performance - Algorithm based failure - signal plausibility failure
- Test Failed
- Confirmed
PDM-Passenger Door
B1165-15 (6C) Front left puddle lamp output - General electrical failure - circuit short to battery or open
- Confirmed
TCM-Transmission 6spd
U0401-02 (27) Invalid data received from engine control module/powertrain control module - General failure information - general signal failure
- Test Failed
- Pending
Post #427377 12th Feb 2017 8:00am
GraemeS
Perhaps the ecm/pcm reported voltage if it's available.
Post #427382 12th Feb 2017 8:34am
bwelton
Thx,
I'm heading out in the cold to check what other Values are available.
I know Voltage is available, but I think it will be at the floating charge level of the Alternator i.e. about 13.5v rather than an internal level from the PCM.
Post #427408 12th Feb 2017 10:58am
bwelton
Ok. voltage at PCM seems a static 14.7V
I have captured a steady idle Line Value graph and included Mass Air Flow. There is only one MAF on the ECU.
I'll try and capture a failure mode graph, but they are pretty irregular intermittent.
Thx
Post #427420 12th Feb 2017 11:47am
Page 2 of 5 <12345>
