![]() | Home > Maintenance & Mods (L322) > Engine Cutting Out Intermittently - 2012 4.4 TDV8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
Is that definitely the 4.4 TDV8 2012. I can't find it... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
Ok, removed and reseated 3 connectors and refitted.
Ok. Problem still there. I managed to capture of log of the engine waivering in Revs and then cutting out.
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
do you get any variance in the two MAF readings ?? Regards
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
The 2nd MAF's values will be of no consequence at idle. |
who said anything about at idle |
The graph shows engine speed as idle or not much more. The 2nd turbo doesn't get used until around 2500 rpm so I expect that its MAF wouldn't see any airflow.
Hi All,
Perhaps the ecm/pcm reported voltage if it's available. |
Thx,
Ok. voltage at PCM seems a static 14.7V
